Post your Garage charging setup!
imjd
58
20
Vancouver
Have a very simple setup compared to all the fancy garages I see on this forum.
CMD1997
19
6
Smithtown, NY
A very simple setup, still have to paint the wall. Also put a disconnect switch so dont have to run to the breaker which is on the other side of the house.60 Amp breaker, 6 gauge wire. Model 3 red, dual motor, long range.comes Oct-Dec as per website.
hkhemani
58
62
King City
Pretty simple garage setup with Tesla HPWC and side wall protector planning to add parking aid gadget.
5_+JqckQttqck
1,851
1,336
Toronto
I had the HPWC installed in garage and a 2 inch hole drilled to charge on the driveway. Glued in ABS plastic adapter and close with plug when not in use.
Will move/block garage door sensor when in use so the garage door isn't accidentally opened with cord inside.
Better be careful.. opening the door mid charge by anyone looking to get in/out of the garage would yank your charge port out = no bueno.
RedSafari
124
128
Toronto
Here is my install in a high rise condo. The charger is connected to an existing condo panel two levels up, about 280 feet away. 40A breaker at 208V.
There is a meter to keep track of the usage and it will be checked annually by the property manager.
Reactions: MarcoRP
