Post your most efficient trip to work
Discussion in 'Model S: Driving Dynamics' started by AC1K, May 16, 2014.
  1. AC1K
    AC1K Member
    Calgary Alberta Canada
    I managed to get 174MPGe (1.2L/100km) one day, basically hit all the green lights, smooth cruising at 80kph (which is the speed limit)
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
  3. mibaro2
    mibaro2 Member
    Georgetown, ON
    I'll post my numbers soon...I get great numbers going to work..all downhill.
    On the trip home, the numbers climb exponentially.
  4. mnx
    mnx 2013 P85
    Ancaster, Canada
    Is that downhill or what? The lowest I've seen on the trip meter was 139Wh/km a couple weeks ago over 46.3km. And that included a lot of 55km/h driving...
  5. AC1K
    AC1K Member
    the total elevation change is less, but i still have to go over huge hills and some flat areas
  6. Jeff Miller
    Jeff Miller Member
    Chicago
    My most efficient round trip to work (13.6 miles each way) was around 245 wh/m. In warm weather, it's not hard for me to get 280 or less. In the depths of winter my energy use was frequently well over 500 wh/m and I am fairly conservative about using the heater. Toward the end of the winter, after reading a few threads on this forum, I became convinced that part of the reason my energy use was so high was because I was not using range mode. In cold weather and when not in range mode, the car spends a lot of energy keeping the battery warm. In range mode, it spends much less energy on this. I've read that the reason the car spends so much energy heating the battery is so that once the battery gets warm you can use regenerative braking but I haven't seen any analysis of the tradeoff between the energy gained from being able to use regenerative breaking vs the energy spent heating the battery. I suspect that when it's really cold, you spend much more energy heating than you can typically recover by braking. It would be interesting to see an analysis of this.
  7. ZBB
    ZBB Emperor
    Scottsdale
    Negative Wh/mi!!!
  8. LazMan
    LazMan Member
    Toronto
    I drove a 150km round drip with an average of 168 Wh/km. Speed ranged from slow traffic up to 130km/hr. How much of an effect do you think my new aero rims are having?
  9. AC1K
    AC1K Member
    Beat myself by 1 Wh/km, im pretty sure it was because the woman in the Maxima behind me tailgated me all the way to work.
  10. N4HHE
    N4HHE Member
    Madison, AL
    I've seen 225 Wh/mi for 11 miles from charger at home several times without making special effort, moving with traffic, maybe even faster.
  11. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    +1 Lloyd. As I often ride my bicycle. Not only does it get terrific MPGe (more than 5000 miles and I have yet to need a charge) but it is great exercise as well.
  12. mnx
    mnx 2013 P85
    Ancaster, Canada
    LOL. I work from home therefore I use zero energy to get to work.
  13. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    563Wh/mi for 100 mile commute.
    oh my bad, you want most EFFICIENT drive to work, not inefficient. well i don't have any efficient driving days. sorry.
  14. AC1K
    AC1K Member
    Beat my own record again, this time a nice lady in an white Acura RDX tail gated me to work... man i love tail gaters! im wondering if the size of the vehicle was a significant factor or if it was just 1 light.
  15. AC1K
    AC1K Member
    SO CLOSE to getting 200MPGe....... maybe if its 25C out i can do it.....
  16. mnx
    mnx 2013 P85
    Ancaster, Canada
    The only time I can come close to your numbers (or even beat them) involves a 200ft elevation drop down the Niagara escarpment. Not sure how you can do it!
  17. lloyds
    lloyds Active Member
    Bay Area
    I've dropped down below 200kwH, but that was with me going local to avoid traffic. That was about an hour's worth of local driving to get to it at approximately 30mph
  18. Pate
    Pate Member
    Finland
    Hey AC1K, I'm at 199 Wh/km lifetime average as well! :) Still ways to go to reach your commute numbers, though...
    Still, I've only had the car for a week, so without the numerous test drives I've given my averages will probably still come down.
  19. ABVA
    ABVA Member
    Northern Virginia
    How in the world did this happen?
    LOL if you can answer this, you may have the answer for world energy crisis.
  20. yobigd20
    Skaneateles, NY
    Easy. Always drive downhill.
