Would people really pay $20k or more for same battery pack capacity but 150lb less weight? You'd be slightly quicker but sounds like they are addressing that with better motor...etc. I think the added range with the other speed upgrades will be a nice upgrade.
A pack made with 3400 mAh cells vs 2200 mAh cells but using 1/3 less will make a pack with about 3% more capacity.
It should weigh 210 pounds less in pure cell weight - but about 250 - 300 pounds less depending on how much they can save by eliminating interconnects and all the other stuff to support connecting, cooling and holding the 2277 missing cells.
( Saving 250-300 pounds will add some range - maybe 5% but likely much more during high performance driving with lots of accelerating )
I assume that an 85+kWh Roadster pack ( made with 6831 of the 3400mAh cells ) would offer more range, but very little additional performance with the current PEM and motor because they can't handle more power.
If they offered the new lighter same power pack today for $20k it would be likely be a no for me, because my pack is within about 2 or 3% of new right now - and that would feel like wasting $20k.
However if my pack needed to be replaced today I would want the lighter one for sure - because I want more performance, not range. My Model S will be my long distance drive car. If you take your Roadster to the racetrack, your time on the track is not limited by your battery size, it is limited by your recharge rate ( ignoring the motor heat issue ). With 85kWh you'd get longer sessions, but then you would be plugged in longer.
From another angle:
If Tesla gave me two options that had the exact same acceleration:
a) 300 pounds lighter
b) same weight, enough additional power to be the same as (a)
But option b was longer range and cost more, I would absolutely choose option a - because 300 pounds lighter will be faster around the track because it will brake better and corner better.
Lastly:
All of this could change if I have a more powerful water cooled PEM and motor in my Roadster. Then additional battery power would not be wasted and I would have to weigh the options again.
