I have no idea how you've run your numbers, nor do I know whether your math is correct.
4000 miles/year, 40 mpg. I already know the Model S is in some sense uneconomic for me. :-( Apparently the vampire load is only 3 kWh/day, which is an amount I can justify, however, as I said.
- - - Updated - - -
So you drive say 50 miles to the airport, park, go on vacation for 10 to 15 days... will you make it home?
Let's use my numbers. I expect to get 300 miles out of the big battery due to speed limits here. 60 miles to the airport, 15 days away @ 10 miles per day is 150 miles, 300 - 60 - 150 = 90 miles. So yes, I'd make it home.... unless cold-weather losses ate up those last 30 miles of charge. I'd be doing this in February, mind...
Yeah, I would be a lot more comfortable with a smaller vampire load. Perhaps the new "sleep mode" will provide that?
- - - Updated - - -
That's the charge point map. Stations only show up when the software is active, which means that the stations are live.
Well, that's good news. I'll go check again!
Edit: looks like the replacement of the ficticious stations was successful. That is very much good news.
Further edit: OK, still none at the train station, but there are some across the street at Carousel Mall. I doubt they'd let me park there for 15 days, though. So worst case, my model S just needs enough battery to drive from the train station to the chargers at the mall (and then I can wait in the mall until I have enough charge to get home). The access card thing (why are most the charging station companies doing this?) is probably kind of a waste given how infrequently I'd use it, but for $25 it's probably worth it. So that solves my problem. Thanks for pointing it out; Syracuse has been claiming to have chargers for several years without actually having them available, so it's very nice to see that they finally got it working. Makes trip planning a *lot* easier, since it fills in the biggest gap.
