Power From A Rock Filled Train
Discussion in 'Energy, Environment, and Policy' started by 182RG, May 16, 2016.
  1. 182RG
    182RG Free The Service Manuals From Tyranny
    Virginia
  2. 1208
    1208 Active Member
    UK
    Couldn't you do something with a lift and go straight up, that way footprint on ground is minimised. Less space or real estate taken up.
  3. 182RG
    Virginia
    Hopefully a physics-type will chime in. (I am not) My guess is there is some type of physics reason that the car generates (conserves?) more energy than a lift due to some obscure law of physics?
  4. strider
    strider Active Member
    NE Oklahoma
    More likely they already had the land and train tracks. Plus you can use a lot more weight on an inclined track that is supported by the earth vs trying to build a tower strong enough to hold all that weight. You would spend a lot of money/energy building the tower which would dramatically increase the ROI.
  5. RDoc
    RDoc S85D
    Boston North Shore
    No, the energy is just the weight times the height, the incline doesn't matter.
    I wondered about that also, and my guess is that they want to use off the shelf train components. To do something like an elevator, you'd have to have a VERY strong set of cables to suspend it. With the train on a gentle incline, the friction of the wheels on the rails would be enough to keep it from slipping.
  6. adiggs
    adiggs Active Member
    Portland, OR
    The video is worth watching, and helps explain why a tower / straight up lift isn't as effective. Part of the system they've built is that each car moves independently, with an intended steady state of a stack of cars somewhere in the middle of the track. Then you can have cars at the head of the stack go uphill when there is surplus power, with more and more cars going into motion to absorb more excess power.
    And you can have cars going downhill. The key is many cars moving at different speeds to adjust to the power need / excess, and an independence that would be difficult in a tower (does each weight moving up and down have it's own independent set of cabling?
    That is indeed slick. I wonder how much track and elevation gain you would need for the scale that makes this economical would be? I didn't see that addressed in the article or video.
