Power from solar tiles seems crazy high
fehguy
12
65
Palo Alto, CA
OK so I got my solar tile roof back in Feb and the team did a fantastic job putting it on. Granted it took longer than expected but the end result is better than I was hoping for. There were some changes in the electrical scheduled prior to final permitting when... COVID came along. So I have a finished roof over my head, but I'm technically not "on the grid". I have no data in the Tesla app yet because it hasn't been finaled.
Well I wanted to try things out so I turned it on and it works! And I have numbers that seem pretty much insanely high. I wanted to see if I'm reading this the wrong way.
I have two inverters, one for each side of my roof. From the picture, the visible side gets the morning sun. The opposite side (which is uninterrupted because it has no dormer window) gets the afternoon sun.
If I'm looking at the data the right way, I'm consistently getting > 40kWh generation per day! The specs said it'd be just over 10kWh. What's wrong (or right)??? Of course I turned it off after a few days of testing...
jjrandorin
Nov 28, 2018
7,197
7,980
Riverside Co. CA
OP, I suspect what @power.saver says is what is going on here....
For reference, I have tesla solar panels (not solar roof) and my system size is 8.7, but I see production right now (from late march through june or so) of roughly 50-52 Kwh per day on a nice sunny day.
Edit : we were posting at same time.
With that being said, I find the numbers somewhat interesting, at showing how shading etc can really affect production (and roof pitch). My 8.7 sized system produces annual Kwh of around 12,500 or so.
getakey
985
307
95762
actually 40 kWh seems low. I don't have solar roof, but 11 kW solar panel system. Today I generated 67 kWh. My panels face East and West, but roof is not as steep
Reactions: AdamMacDon
jboy210
4,640
2,889
Northern California
We are also still waiting for final inspection and PTO on our Solaglass roof, but I noticed during "tests" that the roof generates a lot of power (mine is a 12.2 KW). And I think a lot of it comes from the North facing side of the house. The sections where they put the active tiles on the North side are in sun a lot. So the program that Tesla uses to position these tiles is quite accurate. It is nice to see the 2 PWs get filled in a 3-4 hours. Can't image how much power we will generate in summer. Maybe I should add another powerwall to capture more.
patrick40363
1,152
561
Cali
How much is your roof generating? I am going to get a 12kw roof which is more than the 9.5kw Tesla had on my order.
getakey
985
307
95762
just because you have panels versus roof doesn't mean they are facing South. I have 40 Panels (11.8kW). My roof faces East and West. I have more panels on the East roof than on the West roof just due to roof structure. On Tuesday, I produced 67kWh. Yesterday was 64kWh
Racerx22b
@unplggdd on Instagram
Nov 17, 2014
902
988
West Palm Beach, FL
I have an 11.69kW system and my max daily production on a southern facing roof with no interruptions (basically a perfect day) of exposure is around 70kWh for a single day. I am located in south FL and have panels (not solar roof).
Mar 15, 2020
56
23
Columbus, Ohio
Your roof came out looking really well! Congratulations!
msm859
321
435
Do you have a solar roof or just solar panels? Am 11kW solar roof will have less production than 11kW of south facing solar panels.
I have solar panels 16 facing 122 degrees, 16 facing 212 degrees and 3 facing 302 degrees. Although pure south might give you higher production, given peak pricing periods there is a benefit to facing south-west.
Sonus
130
91
San Jose, CA
Interesting, I have a 7.56Kw system and I am generating over 40KW on a sunny day. I always thought that I am on the low side and when summer comes it will generate more. From the looks of things, the system is solid.
Reactions: Rudolf
