Hayseed_MS
Spreader of "Endless Non Sequitur"
Was looking at the EVOffer and their website states that the power wire is not plug n play - wire stripping will be needed on the refresh.
Thanks for sharing. That is a deal-breaker for me. Not that I can't strip wires, I'd rather not. Just one more place to potentially have issues.Was looking at the EVOffer and their website states that the power wire is not plug n play - wire stripping will be needed on the refresh.
I have not looked closely at the kit that just arrived but the previous version essentially attached to the 12v battery. I'm expecting the new one to do the same.Was looking at the EVOffer and their website states that the power wire is not plug n play - wire stripping will be needed on the refresh.
That is pretty much like the previous version. No splicing of wires then either.This is the end of the 21 refresh evo offer power frunk wiring. The B+ is the positive battery and GND is ground. The B+ has a spade connector. You can either add a Y connector like the ground side or splice back to the bare wire and wrap the positive battery terminal. There is no splicing of factory wires. Hope this helps. I just got my kit yesterday.
Upon further review. There is this piece. So you connect the y side of this to the positive battery post and then the spade connector of the B+ wire into the white plastic connector. The black square is the fuse. So there is no splicing required at all. Sorry first time looking at the wiring.This is the end of the 21 refresh evo offer power frunk wiring. The B+ is the positive battery and GND is ground. The B+ has a spade connector. You can either add a Y connector like the ground side or splice back to the bare wire and wrap the positive battery terminal. There is no splicing of factory wires. Hope this helps. I just got my kit yesterday.
I hear you. I can barely get a kid into it any more.Its a shame the frunk has shrunk so much since the orignal. I use it all the time on my 2014 Rwd and find it super convient its about the same size as a regular cars trunk. On the Plaid its so small as to be barely useful though.
I installed mine today. I didn't strip the wire for power. I put the hook connector flat against the post and put the cap over top of it to hold it in place. The cap locked in place. It seems to be solid, but time will tell.There are installation instructions for the model s refresh (Mark 5)
Electric Frunk (Variant C MARK 5) - EVOffer Installation Guide
No video yet but expect one soon. It looks like you do have to wrap the wire around a post but no splicing required.
Yes exactly the same. That’s normal.I installed mine today. I didn't strip the wire for power. I put the hook connector flat against the post and put the cap over top of it to hold it in place. The cap locked in place. It seems to be solid, but time will tell.
The frunk closes all the way but then raises back up about 1/4 inch. Still shows and appears shut and locked.
Also, makes a pretty loud pop when it releases to open. I may have to adjust the latch placement, just not sure which way to go. I'll mess with it more tomorrow.
If anyone else has it installed and can see if their frunk raises back up slightly after closing or makes pop noise when releasing, I'd appreciate it.
Thanks alot nice to have some reassurance.Yes exactly the same. That’s normal.
Yes double click frunk on key fob to open and double click again to close. I just tried it.With this power frunk install, can you open & close the frunk via the key fob?
Is there a certain button press routine to do this?
Thanks.
Thanks!Yes double click frunk on key fob to open and double click again to close. I just tried it.
