There is no programmatic way to do it you just can remove the cover and remove the tweeter@BigTonyTones is it possible to turn off the beeps? Or to make them super quiet?
The version 2 Power Liftgate from COzero has the beeper in a separate box which can be connected or disconnected to taste.
I upgraded my 2017 S75 to the MCU2 and FSD computer. No issue with my aftermarket power liftgate. The app still can't open/close it properly but that's been like that since before the upgrade. All other controls operate it with no issue.Did anyone with aftermarket power liftgate got MCU2 upgrade? SC told me upgrade requires Tesla power liftgate control module and the aftermarket one will no longer work after install. Anybody have any experience on this? Thanks.
Did they install liftgate control module when they upgrade yours? Where did you tap the power for 12V? Thank you.I upgraded my 2017 S75 to the MCU2 and FSD computer. No issue with my aftermarket power liftgate. The app still can't open/close it properly but that's been like that since before the upgrade. All other controls operate it with no issue.
Not that I'm aware of. I'm sure they didn't know I had an aftermarket liftgate when I got the upgrade. 12V was in a harness on the passenger side behind the side panels in the trunk area. The instructions from the CoZero kit helped identify which wire to tap into.Did they install liftgate control module when they upgrade yours? Where did you tap the power for 12V? Thank you.
Thank you for the info. I tap the power from original liftgate connector. Wonder maybe that is the reason they said my aftermarket won’t work since they must use that connector for their module. I’ll find out when I get the car back next week. Thanks again!Not that I'm aware of. I'm sure they didn't know I had an aftermarket liftgate when I got the upgrade. 12V was in a harness on the passenger side behind the side panels in the trunk area. The instructions from the CoZero kit helped identify which wire to tap into.
I had a full write up in another thread...can't seem to find it now...
thank you for the info. since i tap the power from liftgate connector and they need that connector to power original liftgate module they had to disconnect it which is why they said aftermarket won't work with upgrade. i made a wire harness to bridge the power to both liftgate module and it's all working good now. still not sure why they need to add original liftgate module tho, seems like only thing they are using out off that is a speaker.My lifegate still works fine and I have the mcu2 upgrade
