zanary
1,349
1,513
SF Bay Area (East Bay), CA
Car type: June 28 2016 Build, P90D/L
Battery version: 1063796-00-A
Current software release: 17.11.10
Power with ludicrous (@ SOC%): did not test
Power with ludicrous and max battery ready (@ SOC%): did not test
Power with ludicrous, max battery ready and launch mode (@SOC%): 3.2 second, 61 mph, 449 kw using PowerTools. @ [email protected] SOC
sorka
7,618
5,645
Merced, CA
Doesn't TM-Spy use the OBDII port? That port has limited data out from my understanding - I have the cables for the over cubby data cables, but I'm not sure what software to use for that at this point.
No. The ODBII port is useless unless you want to the 12v supply to power a dashcam.
You need to make a usb to CANBUS cable and connect it to the CANBUS port behind the cubby.
Reactions: hiroshiy
Naonak
796
1,153
Kansas
Ok, that's what I have. I was just making sure we were talking about the same port. I purchased TM-Spy last year, glad to see it's still around.
sorka
7,618
5,645
Merced, CA
Hadn't checked since the 17.11.10 install last week.
Car type: March 31, 2015 P85D (Ludicrouse)
Battery version: 1074980-00-E
Power with ludicrous (@ SOC%): 440KW @ 85%
Power with ludicrous, max battery ready and launch mode (@SOC%): did not test.
This is with a cold battery so it's at least as good as when I first got the L upgrade.
At 90% and max battery ready, it pulled about 456 to 458KW on the last software update but that was warm and 90%.
Walta
333
730
san diego CA
tesla has still not elaborated on the loaner battery bit and whether or not i am supposed to return to swap again. so im just going with this is my battery until told otherwise. part number is 1069582-01-E
Hi @jerjozwik - Did you start with a V2 battery? Which is a 107XXXX part number? Then Tesla replaced it with the loaner 1069582-01-E ? Does anyone know the performance of the 1069582 battery? It seems you are getting less power now with the loaner, than with the V2? I don't recognize the part number from the V1,V2 and V3 's.
What I would like to know is if you have a V1 battery - and it hits the battery warning - can you upgrade to a V3? I would hate to think that instead if you have a V2 or V3 you are downgraded in power to the 1069582 version. Based on the history of Tesla actions regarding this problem, I am very paranoid toward anything they do.
Reactions: St Charles
n2mb_racing
1,108
677
durham, NC
Do you have a typo in your battery version? It isn't listed anywhere in this spreadsheet:
Tesla Model S PxxxD(L) Comparisons (Responses)
Mach Schnell!
P100D Pilot & future Tri-Motor CyberTruck Driver
Oct 27, 2016
105
76
San Francisco Bay Area
Car type: P100DL delivered 12-26-2016.
Battery version: 1086755
Previous software release: 2.50.180
Power with ludicrous (@ SOC%): [email protected]%
Test performed 1-5-2017 (no plus)
Newest software release: 17.9.3
Test performed 3-28-2017 (no plus)
Running PowerTools and recently TM-Spy CAN bus.
Will fill in more data when available.
With latest software update
Newest software release: 17.14.23
Power with ludicrous (@ SOC%): [email protected]%, Current 1782A, Voltage 302V.
Test performed 4-24-2017 (no plus)
TM-Spy used.
No VBOX log this time.
Walta
333
730
san diego CA
Car type: P90DL
Battery version: V3
Newest software release: 17.11.10 (8.1)
Power with ludicrous (@ SOC%): cold 446kw @89% SOC warm from driving @82% SOC 456kw.
Power with ludicrous and max battery ready (@ SOC%): 486 kW @ 100% SOC
Power with ludicrous, max battery ready and launch mode (@SOC%): 500 kW @ 98% SOC
jerjozwik
1,177
659
san gabriel valley
Car type: feb 11 2016 Build, P90D/L
Battery version: 1088792-00-a
Current software release: 17.26.17
Power with ludicrous (@ SOC%): 477kw @97%
458kw @67%
Power with ludicrous, max battery ready and launch mode (@SOC%): 489kw @65%
first spike, without launch mode, second spike with.
sorka
7,618
5,645
Merced, CA
Power with ludicrous and max battery ready (@ SOC%): 458kw @67%
What about max battery at 90% or greater?
zanary
1,349
1,513
hahah, yah i know. but its never ready when the car is at 90%+ in the morning. made a post in P90DL "Max Battery Power" mode asking for tips on how best to prep the max bat ready state. sans supercharger of course.
I usually set my P90DL to Max Batter as I drive up to the supercharger, and then charge to 100%, then find a backroad really quickly and then do my test. I'm normally either 99% or 98% at that point. Don't know if this helps or not.
jerjozwik
1,177
659
san gabriel valley
while i appreciate the response, no it dont.
this morning i set my L2 charge to go from 90% to 100%. which would take 1 hour 12 min or so. turned on max batt power, which said 25 min. by the time i got an almost full charge max batt estimate was still at 25 min. so simply charging does not help... nor does driving. so, sit in the car for 45 min twiddling thumbs?
Naonak
796
1,153
Kansas
Fast charging will bring the pack temp up. If I Max battery a cold battery, it's 15+ minutes. If I DC charge it first, depending on surrounding temp, it's ready immediately or a 5 minute wait. If your max battery is taking 45 minutes, something is wrong. The longest I've ever seen is 25 minutes, which decreases rapidly if I do a few launches. That seems to heat the battery up really quickly.
zanary
1,349
1,513
I've found that max battery is still engaged while I supercharge because I'm still in the car. I could be wrong, but I think it may turn off when I step out of the car while charging or supercharging.
I've usually just sat in the car while I supercharge to 100% (taking a nap or listening to an old episode of Ryan's Tesla Unofficial Podcast.
n2mb_racing
1,108
677
durham, NC
That's odd. I turn on Max battery about 45 min or so before the 100% charge is done. It's ready by the time the charge is done.
It could be there isn't enough amps available at an l2 charger to run the heater and charge until farther into the taper. It works for me at home, but I have 245v @ 40a.
I've also just left the car plugged into the charger at home with Max battery turned on and the battery at 100% until it's ready. I believe it runs the heater off of wall power. Then I leave when it is ready.
Reactions: TIppy
TIppy
1,481
1,100
Tampa, FL
I have a 240v, 50 amp outlet and when the car gets to about 90 percent I turn on max battery. It's ready when the battery gets to 100 percent. Or as n2mb says, you can just turn on max battery after 100 percent charge with the car still plugged in.
