Power Outage - 2 Weeks in a row
Discussion in 'Roadster 2008-2012' started by ibcs, Oct 3, 2014.
Tags:
  1. ibcs
    ibcs Member
    Ohio
    Can't believe our power has gone out two weeks in a row while having a Roadster and Model S fully charged in the garage. Seems ironic to be sitting in the dark with all those joules in the garage.
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Go for a drive?
  3. ibcs
    ibcs Member
    Ohio
    That's an excellent idea everything can be cured with a roadster drive.
  4. adiggs
    adiggs Active Member
    Portland, OR
    The cure for what ails you - a drive in a Roadster.
    That must mean this is a forum of some of the healthiest people in the world! :D
  5. TOBASH
    TOBASH Supporting Member
    Rockaway Beach, New York
    1) Doug is 100%, as are ibcs and adiggs.
    2) Not sure you want to run the house on the battery in the roadster, because if you run her too close to dry you will be SOL.
    3) That brings us back to 1... Go for a drive? (and maybe buy a generator).
    I lived for weeks without power here in NYC after Superstorm Sandy. I feel your pain.
    Best,
    T
  6. spaceballs
    spaceballs Member
    Sammamish
    #6 spaceballs, Oct 3, 2014
    For the roadster you could try an 12v to 120v pure sinewave inverter (i think 1000 watts max if I remember), it might void the warranty of the car. I posted a photo of where the main 12v connects to the car from the ESS, of course use at your own risk. Also you have to make sure water pump is always flowing, easy enough to verify and hear.
