Powertrain Problem Service Required
candersoh
7957farm.com and knotweedfarms.me
Dec 14, 2014
111
79
Boulder co
I was driving from boulder to Denver this afternoon and received this error. Any suggestions?
Panicopticon
149
47
Syracuse, NY, USA
Stefan is correct. I'm working through this currently.
First thing to try is just disconnecting, contact cleaning and reconnecting the fan connector on the bottom of the PEM.
That said, my experience is the PEM fans last about 2 years, I'm on my third set ...
GJVR
139
135
Amsterdam
I agree.
I had the same: I have been getting messages for 3 years: motorfan problem.
Just ignored them, no problems.
I did the annual services.
A few months ago the messages changed to: powertrain problems: service required.
A red light in the dashboard that popped up and dissappeared.
The SC replaced the pem/motor fans. EUR 1,200.
Within 2 months motor fan problem messages again, and also a few powertrain problems service required messages.
I let the SC know but I am reluctant to bring my car there. I try to postpone it until February, when it is time for my annual service.
jfischer
184
245
Houston
I was driving from boulder to Denver this afternoon and received this error. Any suggestions?View attachment 429703
Think I replied to you on Facebook as well.
1144 Error is a PEM Fan Problem.
If you havent had an anual service in a while, you might try that. They take the PEM off and clean everything for $600.00.
If you haven't replaced your PEM FAN, that would be my first guess. Costs about 1K at Houston SC where I had mine done.
2nd thing to look at is the PEM connector that is right below the PEM. There are a few threads discussing how to access it and look at it.
You can order the plug from Tesla or you can order yourself from Digikey or something similar
Molex PEM Connectors
Fan Plug
19418-0004 Automotive Connectors 4CKT RECPT 14-16AWG
0194200009 Automotive Connectors MX150L 14-16 AWG HPA FE SN
From Tesla its
1017064-00-A - CONN, CLIP.LCK, MISC, 004P, CBM, HSG $17.00
Its tight to replace it, but it CAN be done without removing the PEM,
If your good at electronics and crimping pins, you can easily do it yourself. Just takes a bit of patience.
Id Suggest you also look at the connector at the PEM and well, inspect for any corrosion. You can use a phone camera with video so inspect it.
Mine before I replaced the connector looked like. Lots of damage and corrosion on plug pin #1 on the connector which causes the 1144 error.
Bottom of the PEM Plug looks like
Some small corrosion on the mirror pin #1. I just used cleaner and replace just the PLUG on the fan harness.
PM me if you need more details...
BridgetCK
New Member
Jul 19, 2019
4
3
Sidney, BC
That's the exact same message we're getting. Got the same message last summer only then it just stopped working on and off as well. Had to replace all the batteries which happened this spring. We only just insured the car for the summer drove it maybe twice and are getting the same error message. Sigh. Mobile service doesn't know what it is yet so we have to bring it to the shop in Vancouver. This is a very lightly driven car; not impressed with its reliability.
Reactions: candersoh
JensBoll
New Member
Sep 7, 2018
Bjerringbro, Denmark
I have started getting same error. I cleaned the PEM and saw the burned pin 1. I have now ordered new plugs to do an exchange. We really need another solution for the cooling of the PEM to avoid the blocking of the cooling system.
Reactions: ra88it
