Powerwall 1.41
I’m in Arizona with a relatively new install (PTO 10/18) and got 1.41.2 on 10/31. So far my self-powered scores seem to be much higher and the system seems smarter about when to discharge the Powerwalls on Time-Based Control. Lots of variables though so not sure if it’s the software update or just having more history and cooler weather.
May as well add some observations from AU install, so it may not be the same for everyone and the tesla mobile app only shows in 0.5W amounts so you won't see any/all of this, just used 0.3W grid for the day readings
  • Version 1.41
    • Added support for utility grid connections in Switzerland
    • Improved energy performance
    • Additional support for 3-phase Western Australia grid compliance
so still on 1.41.2. with PV.
  • Charging from grid in backup mode now only pulls 3KW (used to be 5 when last tested)
  • Charging from grid in TOU set to 100% reserve pulls 5KW
  • Didn't auto charge from grid when was already in standby at 14% reserve from night before with 16 hours of peak ahead (seasonal setting? it charged itself in winter and start of spring to avoid peak)
  • In off peak time is where I'm guessing Improved energy performance actually is, so off peak drains slower if it's on battery?
ok off peak from midnight until 7am it's like the battery doesn't attempt supply the reactive power anymore (Q) and then sometime during the peak period sends back the overnight used grid amount.
Figures are every 5 mins from the powerwall counters which is why battery flow is 120, 240, 360 etc. peak starts at 7am, the 7am reading is from 655-7am
date, time, battery flow, load, net grid flow
22/10/19 7:10AM 240.000W 264.377W -0.003W
22/10/19 7:05AM 240.000W 249.787W 0.133W
22/10/19 7:00AM 360.000W 360.990W 3.330W
22/10/19 6:55AM 360.000W 362.333W 9.887W
22/10/19 6:50AM 240.000W 248.130W 14.300W
22/10/19 6:45AM 240.000W 240.567W 1.077W
22/10/19 6:40AM 120.000W 124.237W 4.773W
22/10/19 6:35AM 240.000W 245.263W 5.753W
22/10/19 6:30AM 240.000W 240.570W 1.083W
22/10/19 6:25AM 240.000W 243.510W 3.970W
22/10/19 6:20AM 120.000W 124.800W 5.340W
22/10/19 6:15AM 240.000W 241.380W 1.873W
22/10/19 6:10AM 360.000W 363.627W 3.727W
vs
11/11/19 7:10AM 480.000W 618.997W 0.033W
11/11/19 7:05AM 360.000W 483.507W 0.143W
11/11/19 7:00AM 1920.000W 2158.163W 138.760W
11/11/19 6:55AM 480.000W 724.163W 155.250W
11/11/19 6:50AM 360.000W 491.433W 51.000W
11/11/19 6:45AM 240.000W 346.567W 36.907W
11/11/19 6:40AM 240.000W 342.950W 39.127W
11/11/19 6:35AM 360.000W 450.847W 31.543W
11/11/19 6:30AM 240.000W 316.167W 40.453W
11/11/19 6:25AM 360.000W 413.093W 51.277W
11/11/19 6:20AM 360.000W 384.720W 32.633W
11/11/19 6:15AM 360.000W 393.097W 38.513W
11/11/19 6:10AM 240.000W 267.820W 28.100W
