When factoring the cost of PW2, correct me if I'm wrong, the PW2 should be eligible for the 30% tax rebate, and no sales tax in FL.
This is not entirely clear to me, either. As far as I can see, if your PW is your inverter, ie: your solar panels are connected to it, then PW will qualify. I've read docs that say a certain percentage of the batteries must be charged from solar before it qualifies. That's sort of a gray area because you can setup your PW to use only solar to charge the batteries, qualify for the tax credit but later change the configuration to anything you want. Because of this, I believe PW will always qualify when it's part of a solar system.
Yes, a single PW will run a 1500 sq/ft home. It will power all in the home except for the typical central AC units we use here in FL. The PW total energy is 13.5kW but you can only draw 7kW peak, 5kW continuous. That means that hard-starting devices like AC (and some pool pumps) might not start or cause a fault. A typical central AC unit draws about 1.2kW per ton - this varies with AC efficiency (EER). If your central AC is 3 tons then 3 * ~1.2 = ~3.6kW consumption. However, motors use a lot more power when they're starting so those 3.6kW can peak to 10kW (or more) during start up.
Alternatives are:
- Install 2 PWs (~14kW peak start power)
- During an outage, use a smaller, portal or "ductless" AC unit for the bedrooms at night.
- Switch your AC units to higher efficiency, inverter based ones. Inverter-based ACs draw much less peak power.
Still, total capacity for a single PW is 13.5kW. If your home uses 1kW every hour, your PW battery will last 13 hours. That's where solar comes in, as in the scenarios above. Check your utility bill to see how much power you use typically. FPL online shows this by the hour.
JR
