Powerwall 2 Installs in Hawaii
Discussion in 'Hawaii' started by Papafox, Mar 6, 2017.
  1. InParadise
    InParadise Member
    21 25 15N 157 48 17W
    #241 InParadise, Nov 22, 2020
    I ordered only one Powerwall with a 4kW system and Tesla just told me my Utility requires 2 Powerwalls. WTF?? I'm waiting for the why. I hate talking to a Tesla intermediate solar manager.
    2 Powerwalls is total overkill for my household so would not be worth the extra $6.5K. I have an existing 7.5kW NEM.
  2. miimura
    miimura Well-Known Member
    Los Altos, CA
    If you will have a total of 4kW + 7.5kW of solar, you really do need two Powerwalls. They can only absorb 5kW of solar each. The only other option is to put the new 4kW solar outside the backup gateway so that it will remain off when the grid goes down. The system is not stable in island mode with your solar potentially overloading the Powerwalls.
  3. gmtom1
    gmtom1 Active Member
    Honolulu, HI
    Something doesn't sound right. I have 2 PWs with a 5.25kW NEM system + 3.78 kW NEM+ system, but I was only going to put 1 PW originally and changed to 2 PW later during the planning phase, and the advisor that was helping me with planning said it was totally my choice how many PWs I want. I could have gone with 3 PWs too to get me to 100% off grid.
  4. miimura
    Los Altos, CA
    More Powerwalls is rarely a problem until you get above 5. However, there are definitely downsides to having only one. I originally wanted only one but I'm super happy that I got two. The install is also more expensive for one, which seems counter-intuitive at first, but they usually have to divide up your household loads into a critical loads panel for partial backup when you only get one Powerwall.
  5. InParadise
    InParadise Member
    Mahalo for the explanation. This is way better than the confusing explanation the Tesla advisor gave me.
    Now to decide whether to have zero, one or two powerwalls to save less than $100 per month.
  6. Akikiki
    Akikiki A'-Lo-HA ! y'all
    Kaneohe, HI
    You need PWs for your neighbors. WHAT? Well, one PW might be enough for your needs. But you know how often our power goes out. You also gotta know how popular you are going to become when power goes out and your neighbor cousins drop in for a cell phone charge because they can't. And then once the phone is charged, they will be dragging extension cords from their house to yours to plug in their fridge. I mean after all, you do have a Tesla, so you have more than enough range and "juice" and you won't mind sharing. So, you need that second one for "cus'.
  7. fstop11
    fstop11 Member
    Waianae, HI
    For the record, I'm in the camp where Tesla didn't take the photos required for HECO to proceed with meter installation/PTO. My timeline was probably slowed down by the fact that I sent a physical check to Tesla, but no action was taken until I contacted them regarding status. The key takeaway is to manage your own project as much as you can; don't wait for them to do things. Be the squeaky wheel!
  8. InParadise
    InParadise Member
    #248 InParadise, Nov 23, 2020
    I was under the impression that a second system will not join an existing system for energy going into the Powerwall. Now when the grid goes out, will both systems load the Powerwall?
  9. miimura
    Los Altos, CA
    It is possible. However, I would make sure to bring up the issue as early as possible in the process because the placement of the required CTs (current transformers) to measure the both solar systems may not be so straight forward. A guy in Arizona had an old solar system, then added Powerwalls, then added more Tesla solar and the new solar did not charge his Powerwalls because the solar techs did not reconfigure the Powerwall CTs. If you are having new solar and Powerwalls installed at the same time, they should plan ahead for it.
  10. Casper702
    Casper702 Member
    Hawaii
    Tesla says the reason my inverter hasn't been replaced is because it has not been delivered to Hawaii. Solaredge gave me the tracking number that shows it was delivered over a month ago.
  11. Casper702
    Casper702 Member
    Hawaii
    You know one main reason behind me getting solar and batteries was to still have electricity during power outages.
    Well thanks to Tesla's terrible service I'm sitting here in the pitch black while my solar system does nothing.
  12. Akikiki
    Kaneohe, HI
    Me too. And I bet your neighbors are just as upset with Tesla that you don't yet have your PWs and solar. Soon as you are up, they will be able to borrowry a bucket of volts.
  13. Casper702
    Casper702 Member
    Hawaii
    Both my direct neighbors had electricity last night thanks to their solar systems from Kumukit. The annoying part is their systems were installed after mine and are already working.
  14. Casper702
    Casper702 Member
    Hawaii
    Once I called Tesla and asked why it hasn't been installed even though it was delivered over a month ago, they scheduled the replacement for Friday.
  15. Casper702
    Casper702 Member
    Hawaii
    Let's see if they can fix it this time.
  16. Casper702
    Casper702 Member
    Hawaii
    Update.
    The solar is working but now the Powerwall isn't responding and the technical support for the powerwall is off until Monday.
  17. Sunshine808
    Sunshine808 New Member
    Honolulu, HI
    @Casper, the same exact issue for me. Turned on the system only to find out the Solaredge inverter is defective. Now waiting on Tesla tech to come out. Hopefully, they come with a replacement. Is your issue resolved?
  18. fstop11
    fstop11 Member
    Waianae, HI
    Just to add a little data to the conversation, here's my solar timeline:
    Original order: 6/9/20
    Upgraded order to higher capacity panels: 6/26/20
    Install Day: 9/9/20
    City & County inspection: 11/16/20
    PTO: 12/17/20
    Things to keep in mind: I paid by check, which led to a 2-4 week delay between install and inspection; and I did not have the installation issues people like Casper702 had. It is not a quick process and requires active customer engagement to move the process along, especially if you run into equipment issues. You can't just wait for Tesla to take action; you have to be the somewhat annoying/nagging customer who won't shut up until they get it right!
  19. Casper702
    Casper702 Member
    Hawaii
    Yeah my system is up and running, only took 16 months
  20. Casper702
    Casper702 Member
    Hawaii
    When you talk to Tesla ask them for the Solaredge case number so you can track the replacement invertor with Solaredge.
    For over a month Tesla lied to me daily saying the inverter wasn't delivered because Solar edge hasn't shipped it. After I was able to get delivery confirmation from Solaredge and send it to Tesla they finally came out to replace my inverter.
