ESESKeith
I understand what you guys are saying here which has made me rethink how I'm going to achieve this. What about if I use a bridge rectifier to change the generator output to DC. So then I'll have 240Vdc output. If I connect that to a grid-tie solar inverter, the inverter will think the generator is a solar string and will sync to the powerwall. The powerwall should recognise the inverter output as solar (if I thread the active wire through the solar clamp) and charge from it. Only issue here is how to govern the generator output at a constant amperage (ideally 15A which would provide 3.6kW).
Just to note: from your prior note, your "generator" appears to be homemade, an alternator attached to a gas engine. I would not expect this to be even close to good enough in terms of power quality. I expect a fairly high-end generator with sophisticated power quality controls to be required, quite likely (as some have mentioned) an inverter-linked generator. Of course, that's sort of what you're building when you then rectify your AC "generator" to DC, and then run it through your solar inverter. You are playing with a lot of variables here though: I'm a risk taker, but I'm not sure I'd be quite so cavalier with such expensive equipment (the PW and Inverter specifically). But inverters are comparatively cheap these days, maybe cooking a $1000 inverter wouldn't bother you.
