pdxrunr
Perhaps you posted the previously, but what was your total cost before and after incentives?
Thanks
No incentives that I know of. $7K installed and permitted.
Thanks
Sure. If you're in SGIP Step 1, the incentive is $0.50/Wh. PW2 is how big? 13,200 Wh? So that's $6,600 incentive. If Tesla only charges you $7,500 installed per PW, you're only paying $900 each, or 12%.Anyone taking incentives have a come up with a way to pay less than 40% of the install costs?
Well, certainly if it's in the handbook, that's how it is. That makes a whole lot more sense than basically giving people free PowerWalls in the first incentive step.
Although, I don't know how they would know if you took the ITC when you file your taxes next year. The application seems to ask about the intent to take the ITC, not the ability to take the ITC.
The way my SGIP application looks (as prepared by Swell Energy), I will get $11,750 incentive for 2 PW's and the application says I'm taking the ITC. According to my math, if the transaction proceeds according to that document, I will end up with a net cost of 29.3% of the project total if I take the 30% ITC on the net cost after SGIP.
Maybe the SGIP Step 1 is only $5,875 per PW2, I'm not sure. That would still be 21.6% without ITC and 15.2% if you take the ITC on the balance.
Your 40% is about right for SGIP Step 2 without the ITC.
I am in SoCal. Got a quote for 2 powerwall 2s for $16k (including panel upgrade/install costs). Step2 SGIP rebate is coming up to $9280. Net cost of $3400 per powerwall 2.$7k seems feasible though I am not sure what it would cost in SoCal. For powerwall 1 I got a 12k quote
That is correct. Rated charge/discharge capacity of Powerwall 2 is 5kW. SGIP rebate for residential is capped at 10kW. So max 2 Powerwall 2s only.SGIP limits you to no more than 2 Powerwalls (so Tesla tells me). A third would be 100% on you to pay for.
In OR with no incentives around, a $7k install sounds right. In CA with major incentives - a $12k install sounds about right. With incentives on the table (plus higher permit costs in CA, which can be crazy-high in some areas) then they will up-charge installs to soak up some of that incentive. "You're getting SGIP and ITC, right? Let's bump the price and you won't even feel it". The SGIP looks to be a veiled "Jobs Program" for CA - perhaps written the way it was by people very close to the battery-making companies there. In the past, they boosted SGIP payout for companies based in CA - but Tesla now makes PW in Nevada.
Reminds me of the time I was offered a "Free" Level 2 Blink charger in 2013 from my local power company. Only $1100 to install the wire and mount the unit by the pro-electrician with the beautiful installation truck and gear who gave the estimate.
Any time during the PowerWall sales and install process - do they ever explain round-trip charging losses for those folks who are using it with Solar PV (or grid overnight charging)? Has there been a printed document with the round-trip efficiency numbers offered of PW2?
Very cool. Was your installation part if sgip? If so, did you factor the discharge requirement into your decision?
I don't think the math is that simple. AFAIK, SGIP requires you to pay a minimum of 40% of the total project cost after all incentives. It appears that if you say you will take the ITC, then SGIP will give you less. I am inclined NOT to take the ITC because the system usage terms are less restrictive for SGIP than ITC.Just want to confirm with the board based on what I have been reading.
If I am in Step 1 and want to claim the 30% Tax Deduction for the Battery System Install.
The SGIP Rebate with no ITC is $.50/wh and with ITC it is $.36/wh, do I have it right?
