detlefo
Thanks... Amazingly it works the same way in Android.On iPhone, top right and bottom front at the same time, then in Safari, upload a file, which it will have as a picture.
I'm also in the same boat as you. Quantity 2 Powerwall without solar. I was told looking forward to Time of Use Load Shifting, but alas it won't arrive until end of year, but that's ok, because for the past two weeks I've been manually flipping my breaker on and off to do it myself.
So far it's been pretty cool, my usage is is around 15kwh so I'm pretty happy.
One more hiccup..
Did they hook AC condensing unit on the backup too for you? Tesla hasn't hooked mine on the backup, saying AC cannot be ever backed up. which means nothing can be TOU-shifted when one wants to turn the AC on. Which is like 70% of my use case and motivation during these summer times. The case is still open though, maybe that could be done, my CU says max 40A fuse on it. which means it probably cannot draw more than ~8kw even at its peak (customary 20% breaker derate engineering assuming). Ongoing observed draw is ~4kw which is less than some of my other uses (e.g. electric dryer) which seem to be working just fine.
Interestingly, if that's so, then AC cannot be efficiently used even with solar either. Yes one can perhaps charge solar to the battery but the house will have to be 100% on the grid while AC is still running meanwhile...
By the way, at least when I tried back in June, the Tesla gateway was unable to recognize the neur.io when connected via a wifi extender. Possibly it is recognizing the neur.io connection via the wifi clients list instead of the dhcp lease table. The other possibility would be if the gateway supports RS485, then something like this RS485 ethernet bridge would work (RS485 Ethernet Adapter - NET485 | Grid Connect). Honestly everything would be so much more straightforward if the units connected directly to my home wifi network (both the neur.io and tesla gateway) ..
Hm i am 2 PWs too... why the story told is so different then... I need this on backup, it defeats the purpose, there's nothing else to eat up that ~25kwh usable supply but the AC.. Yesteray, i ran backup without AC from 7am to 11pm, washing, drying, cooking, working from home (computer etc all day) barely got down to 50% charge.. That much capacity doesn't make tremendous sense without feeding it to AC.That was one of my initial questions. If Whole Home Backup included everything (except for my Tesla Wall Connector running on 240/60). They said Yes and that's what the engineers did when they put together the quote and the design for me, and the installer said yes, that how it was designed. They also gave me the option to remove my AC (which is a 5 ton unit with compressor), but I decided to leave it on the Poewrwalls. I don't use it that often, and when I do, yes it will deplete the Powerwall pretty quickly. I don't know if it matters, but I have two Powerwall units, and I'm close to achieving the Red one in the next 80 days
I think you're misunderstanding how the system works. Which loads are on the backup panel is only important when the grid is down. Those connected loads on the backup panel are the only loads that will work during a utility power failure. So, you cannot run the A/C or charge your car from your HPWC, or use other high drain devices when PG&E is down. When the grid is working normally, the PowerWall can still offset your usage and drive the meter to read zero while you are running your A/C.One more hiccup..
.I think you're misunderstanding how the system works. [...]
I just had a funny thought. What if you re-provisioned your system as though you had solar? You may not have enough CTs to do it and you may have to trick the system with some fake CT readings from your charging station, but if you tricked the system into thinking you had solar, at least you could activate the Self Consumption mode. Then the only thing you would have to do is change the mode each night and each morning back and forth from Self Consumption to Backup and back again..
Yes exactly what zanary said. no solar. I have two EV cars ...
Refer back to earlier posts in this thread about how to re-do the provisioning.
my newly installed one shows 1.7.0I have also received 1.6.0?
Wow. Very Cool. I'm still on 1.6.0 as of last night. I'm wish Tesla would publish release notes for PowerwallOS so we know what's in each update... I'm hoping that Time of Use Load Shifting arrives with 2.0 by December 31st as they have indicated.my newly installed one shows 1.7.0
I had my 2 Powerwalls installed a week ago. At first it showed 1.7.0, a few days later, it was downgraded to 1.6.0!my newly installed one shows 1.7.0
Could you please point me approximately to the page #? i searched the whole thread for "provision" keyword but found nothing about how to get to those screens? Also tried to just do general search outside the thread, nothing that would resemble such a hack.Refer back to earlier posts in this thread about how to re-do the provisioning.
I have 2 Powerwalls directly hooked up to the main panel (as whole house backup). I also have two 3 ton AC units. Without the grid, no even one compressor can't start. It seems that the voltage drop is too much for the compressor to handle. With the grid online, both can be started and run on the 2 Powerwalls.I have my AC (5 ton + coils) all running on the Powerwall at this point.
The post seems to be missing. If you Google "Powerwall password site:teslamotorsclub.com" the first result shows the post, but only if you look at the cached version. TLDR: it's the unit's serial number.Could you please point me approximately to the page #? i searched the whole thread for "provision" keyword but found nothing about how to get to those screens? Also tried to just do general search outside the thread, nothing that would resemble such a hack.
But that's similar to what i thought. All we need is just schedule that switches between self-consumption with 20% backup (day) and back to backup (100% backup) at night... Seems like something that is already there, less the preconfigured scheduler. But i would be quite ok with a software switch if it means i dont have to switch the grid off and have discharge as a priority during the day...
Thanks!
P.S. oh.. you mean the port 80/wizard of the gateway? it is password protected, it seems..
