Powerwall capacity not utilized?
schrodarkian
41
29
Also received a call today from someone assisting my original sales person, apparently they never filed for PTO and had me sign some paper that they forgot initially (ugh!).
I *believe* as long as you paid in full for the system in 2019 you should be able to claim 30%, not 2020's 26%.
getakey
992
307
95762
Re taxes, my understanding is that any project started in 2019 is eligible for 20019 tax credit. D not have to have fully paid in 2019
schrodarkian
41
29
I realize that an "I believe" post is worth about the same as a used teabag, so here's what the SEIA says about it. I think they have more attorneys on retainer than me. o_O Per their statement: if you paid for the install in 2019, you're good. If you paid (at least in part) in 2020, it's 26%. Highlighting is mine.
Reactions: jjrandorin
charlesj
1,017
208
Monterey, CA
A call to technical support seems like a good idea at this point to inquire about this and confirm. It might take a few weeks to investigate on both sides. Keep calling them whenever you have some new information to push Tesla along.
What he could do, just came to me and just a thought, is turn off one PW by that side switch and see what happens for a day or two or several. Then, do it to the other side.
If one is bad, extra solar will go to the grid, nothing to PW, my thinking.
getakey
992
307
95762
tax credit - must be different opinions on this
According to IRS Notice 2018-59, to gain the full 30% tax credit by December 31, 2019, you must pass one of two tests:
  • “Physical Work Test,” meaning proof that construction is underway.
  • “Five Percent Test,” that illustrates you have incurred at least 5% of the total project costs by December 31, 2019. Permits, site assessments, plans, environmental impact studies — all of these costs qualify under the test.
jjrandorin
Nov 28, 2018
7,261
8,040
Riverside Co. CA
That doesnt apply for residential, I dont think, especially that 5% test. See the post from @schrodarkian
Reactions: schrodarkian
schrodarkian
41
29
I think they have different standards for residential vs. commercial projects. From what I understand the “construction underway” test applies to commercial only.
Thanks as always to our government for making things clear. o_O
CA SGIP is worse. Spent a little time trying to understand that when I was considering using a 3rd party installer.
schrodarkian
41
29
Yep! Section 48 is commercial, 25D is residential. It seems the law is much clearer for commercial.
“Placed in service” for residential has been interpreted to mean different things. Some have told me it’s when you get PTO, but that seems absurd since you’re waiting on a utility to get around to it. I wouldn’t have even thought waiting for county or city inspection should count. I took it as, all work has been completed and it’s verified operational, and you’ve paid for it.
Tesla turned on my system the day they installed. Kind of a wink wink thing. I couldn’t get NEM credit but I was producing solar. Whether or not they do that routinely probably depends on jurisdiction.
charlesj
1,017
208
Monterey, CA
The app tells you when one of the powerwall breakers is tripped. I had a bad breaker on one of my powerwalls a few months ago that kept tripping. The other two powerwalls worked fine (charging and discharging), while the third was disconnected. Here’s what it looked like in the app:
Interesting, thanks. But, if I am correct, may not be, if the PW has other issues not a breaker, that would not show up as throwing the breaker does. Then you'd have to keep an eye out almost constantly to make sure they keep working. So, if you breaker off the good one, the bad will not charge and one can see that.
Having read about at least 2 PW going bad, an firmware update to show a bad PW not just a breaker issue would be great. Actually, a notification is in order as not everyone keeps a constant eye out.
DHevey
25
16
Bluffton, SC
That's good to know, but I didn't get that message. All looked normal when it happened to me.
