Powerwall charging to 97% max instead of 100%?
Discussion in 'Tesla Energy' started by af88, Nov 23, 2019.
  1. af88
    af88 Member
    Cali
    Curious if anyone has this problem as well. I got 2 new powerwalls put in yesterday finally. Gateway Firmware is updated, Set to Backup mode and today it topped off at 97% not 100%. Not seeing it charge to 100% can't be normal i suspect. Screenshot_2019-11-23-15-35-03.png Screenshot_2019-11-23-15-34-48.png Screenshot_2019-11-23-15-34-43.png
  2. charlesj
    charlesj Member
    Monterey, CA
    Don't have an answer for you on this but a question. How long was your process, end to end?
    City?
    You may be lucky to get two PW as what I hear, fire code may limit it to one in a garage.
  3. power.saver
    power.saver Supporting Member
    Arcadia, CA
    Charging to 97% is normal in backup mode. Sometimes to 98%. In other modes, it will get to 100%.
  4. DrSmile
    DrSmile Member
    Northern NJ
    Totally normal.
  5. patrick40363
    patrick40363 Active Member
    Cali
  6. charlesj
    charlesj Member
    Monterey, CA
    Sure would be nice to see each battery on its own on that app. ;)
  7. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Yeah mine are ‘fully charged’ (daytime with sun out) and they are at 97%. Don’t worry about it. They will charge more when storm watch/disaster watch (what happened to this renaming?) enables in bad weather.
  8. boaterva
    Before anyone falls over who isn’t aware, this is a California thing. I have 3 and some have (many) more elsewhere.
    I still don’t get the code issue. Hope logic (lol) can prevail on this. One PW doesn’t back up much.
    Was there any progress on the idea that these units were exempt because of whatever standard they did meet?
  9. chrisbailey13
    chrisbailey13 Member
    Central Florida
    I think if you switch to Self Powered mode it will charge to 100%. You can always set it to self power mode and set the Power Outage reserve to 100%.
  10. af88
    af88 Member
    Cali
    They are mounted outside on the side of the house so it wasn't an issue. As far as process it is still not finished, they failed inspection b/c the installers tried taking a few shortcuts, nothing major but they have to come back out and stucco lath for inspector to pass than stucco the hole they cut.
  11. af88
    af88 Member
    Cali
    Thanks guys very reassuring this is normal.
    If is switch to Self Powered Mode will Storm watch still function? My intention installing these was strictly for backup power but If i can get an extra 3% and use self power mode + storm watch than what is the harm?
  12. CSFTN
    CSFTN Member
    Memphis, TN
    I had a bid for 6, in TN by Lightwave Solar, who state they are an official Tesla partner.
  13. cwied
    cwied Member
    San Mateo, CA
    Yes, Storm Watch works in all modes. The only question in my mind is if the 97% is intentional in backup mode to preserve the batteries. I don't use backup mode, but if it truly is a feature that it only charges to 97%, it might make sense just to live with it. 3% is not that much extra runtime in the scheme of things, and if there's a high likelihood of an outage, Storm Watch would likely kick in anyway.
  14. af88
    af88 Member
    Cali
    I was just concerned if the 3% was due to a defect. The fact of the matter is i don't think this battery is fully charged to 100% in terms of cell voltage. Li does not last very long if it fully stored at 4.2V for example for a long time. I never did get an answer back from Tesla on this in terms of real capacity and how that 100% or 97% translates to cell voltage. My guess would be even at 97% it does not mean the cells are fully charged so why not just allow the 100% charge relative to the actual voltage. Mine actually went up to 98% today. Just more curious than anything but it sounds like based on everyone's feedback it is normal.
    Thanks for the tip on storm watch, I might go that route to use self powered mode and reserve at 100% if it acts the same exact way as backup mode with the addition 2-3% of the relative voltage what ever that may be.
  15. boaterva
    97% is not. :D. From what I’ve read 100% is approximately 90% actual for just that reason so you can run at ‘100%’ forever and not worry about it. Stormwatch then is supposed to charge as much as possible above that so it goes over ‘100’ for the duration of the event and then normal usage will eat it up back down to the normal 97 or so.
  16. KY-Lonewolf
    KY-Lonewolf Supporting Member
    Kentucky
    #16 KY-Lonewolf, Nov 25, 2019
    I have four (4) powerwalls that have been installed for two months.
    I run them in Backup-only 100% mode.
    They currently, in 50 - 60 degree weather, charge every other day to 99% SOC. (per Tesla app)
    Over two days they drain to 96% and then charge back up to 99%.
    I don't know if they would perform differently in warmer (or colder) weather....... time will tell.
