I'll try turning all the breakers off except the Powerwalls and see if I can get them charged up and keep the solar system running before I turn anything else back on. Fortunately the gateway also had a cellular connection so I can monitor what's going on.This suggestion is a bit late, but in the morning you could try turning on just your smallest inverter and shutting off all your loads via the breakers (maybe you need to leave on a router to talk to the Powerwalls to check status). If that is stable, then I would suggest there is either a problematic load, or the Powerwalls are limiting their charge rate due to temperature and state of charge. You can check for the latter by turning on all the inverters with no loads to see if it holds; you can check for the former by doing a binary search on your load breakers.
Cheers, Wayne
Someone from Tesla is coming by before noon. Hopefully I can get things working before the pipes freeze in the radiators. That happened once before and is one of the reasons we got solar and Powerwalls installed!
