Did you make this table yourself?
What could be interesting is *if they can* add a small solar and 1 powerwall. That might be worth spending more money if I can keep the old solar working with it together.
Or compare to the price of a generator....
Yes. I made the table myself and occasionally update as needed. Powerwall only pricing is accurate as I checked it to user posts on TMC.
If you have the roof space, then it is possible for a small solar (3.78 kW) and 1 Powerwall to augment your exisitng system. Do note, per the
Tesla FAQ/support page: "Since Powerwall 2 is an AC coupled solution, it is compatible with all inverter types. To ensure reliable operation during power outages, at least one Powerwall is required for each 7.6 kW AC of solar included in the backup circuit."
Your existing 3.8 kW and the small solar 3.78 kW should fit within this requirement. The only thing I can not answer is if your inverter would be compatible with the Powerwall. I have non-smart, utility interactive, Enphase M-250 micro-inverters that responds to the Tesla energy gateway. Check the CA state list if your inverter is listed:
Inverters
If not, perhaps the balanced approach is to have your old inverter replaced with a comparable one and add on afterwards.
