Okay, here's my current thinking the three options.
1. Buy one powerwall $7,600
2. Buy two powerwalls $14,100
3. Upgrade to a new system 7.56kW $24,790 after tax credit
I think but am not sure that I have eliminated just one Powerwall. I would like to be able to be relaxed if and when a power outage occurs. Just one Powerwall might be enough. But two ready to go during wildfire season would be quite comfortable with charging the Tesla at the superchargers nearby.
The new solar system would be double of what I have, which is fine. I don't really mind giving away electricity for free as it helps the environment.
I got one response on donating the panels, but no follow back email yet. Sounds like it is not an easy or standard process. I may end up trying to find a friend who can use it instead or selling them for a marginal amount of money if I don't hear back in a few days. I looked through craigslist and there doesn't seem to be much selling of old solar systems - just a panel here and there for $30.
Very much on the fence still but appreciate everyone's help. You are all much more knowledgeable than the folks at Tesla. One person did give me a specialist that I could call but haven't done so yet.
Is it worth the effort to look at other solar companies? I am not a nickel and dime person.
Any strong opinions on the three options? My electrical bill annually will only be $500 max with the existing panels.
Just to double check - is storage your only consideration for the extra Powerwall? As has been alluded to here on the thread, though in somewhat muddied terms, is that each Powerwall has a 5kw inverter limit. You mentioned you're only interested in backing up relatively low-wattage appliances (fridge, freezer, router, etc) but if you have an air conditioner or electric oven, dryer, hot water heater, etc that may tip you to get a 2nd Powerwall so you have the option of running those appliances (even if for short periods of time).
Inverter size aside I did a lot of the same calculations you did as we were putting in our 8.55kw system and looking at the Powerwall for backup only. We opted for only 1 Powerwall because:
1) Our outage scenarios are relatively short but not uncommon weather related outages (<24 hours) and as I mentioned with some moderate conservation one Powerwall would last that with absolutely no input from the PV (which is pretty uncommon)
2) We don't need high wattage appliances during an outage - it doesn't get warm enough here to necessitate running the A/C but it's nice and the water heater is a tankless natural gas one that draws little power when in use (actually ran it on a computer sized UPS during an outage before our system was installed, fun story)
3) In an emergency I can charge my EV with a backed up 120v/15a outlet (though not great it will do in a pinch)
4) In an extreme situation, like an earthquake or extended outage, I have an inverter harness kit so I can use my EV to power appliances directly to reduce draw on the Powerwall + PV
And probably most importantly:
5) Until the utility starts TOU pricing the battery tech is only going to get better so we opted to get only 1 with the thinking that later down the line we may want to get a second or whatever "Powerwall 3" is.
