Once you plug in the Ethernet cable. you'll probably need to run Setup wizard to get it to use wired Ethernet.hello, I have just had a new powerwall 2 installed and I want to configure the system to run via a wired Ethernet rather than WiFi which we do not have, how do I do this?
Not many people have wired Ethernet on the side of their house or in the garage. It would be an strange requirement to need that for an install.When they came out for my site survey, they wanted a photo of my router to verify that wired internet was available.
So it's odd that you had an install without internet.
Is this a self-install? I saw someone on Facebook selling a Founders Edition Powerwall, buying one greymarket like that would seem to be the only way you could get one without professional installation.
I gave my installer my WiFi credentials, but they did not use it. Mine is communicating on cellular.
Nope. I have the Enphase gateway wired by Ethernet. The Tesla gateway needs its own internet connection.Interesting. I was never asked for WiFi credentials. However, when they installed my solar months earlier I did provide it. Curious if it can use the same receiver as the enlighten gateway? I’ll have to check that out.
Powerline Ethernet bridges are small. It would be easy to wire one up inside the Generation Panel or Gateway enclosure and put the other end in a room that had easy access to the LAN.Is the WiFi 5GHz compatible? Getting tired of too many devices only supporting 2.4 GHz.
Would be best if it had some sort of power-line ethernet.
5GHz has a much shorter distance than 2.4, so you won't see it replacing most devices, only as an option.Is the WiFi 5GHz compatible? Getting tired of too many devices only supporting 2.4 GHz.
I'm in a crowded 2.4 area. Neighbors 10 feet away on two sides, and 50 feet away on other two sides.. Then, I've just upped my number of IoT devices. It about as crowded as an apartment area, via "WiFi Manager" scanning on Android.2.4 is better than 5, unless you have a crowded neighborhood with a lot of 2.4 networks and few 5s. 5 is faster at short range, though. Not important, I'd imagine, with a Powerwall's bandwidth.
I live in the middle of nowhere. Rarely can I see one of my neighbor's networks.
