This thread has me wondering if I should spend the extra money and install in my garage, probable would cost around $1000 to run the conduit thru the attic to the main panel.
A pretty easy install is two guys for 4 hours, maybe 6 at the most, including a lunch break.Nonetheless, it took three guys, two full days so far, and they're coming back for another half day or so.
That is absolutely gorgeous from an engineering perspective.Photographic data point;
It's hard to conceive this is a residential installation where just a few years ago you would never imagine such a thing.
I would had preferred raising a little bi the Powerwall from the floor, to allow easy cleaning of the floor or future painting.
May be I would but some piece of wood around the base to act as a bumper to avoid any damage when cleaning the floor.
FWIW I usually just vacuum the floor and use a crevice tool at the bottom of the Powerwalls. Today I wet mopped the floor. No damage--all good. BTW the concrete floor is coated with this:
Polycuramine® Garage Floor Coating Kit
The prep is a bit of a PITA (clean and acid etch concrete, allow to dry, test residual moisture content). The 2-part mix cooks off very fast and is really hard. Hot car tires don't faze it a bit. It is slippery when wet--but I don't like the look of the granules you can sprinkle on.
Is there an allowance to have the powerwalls not right next to the meter? Our meter is in a bedroom in the basement and I have been trying to get Tesla to look at installing the powerwalls in our utility room about 30-40 feet from the meter instead. Over the last three months, the only responses have been that the install team will look at it when they show.
Does anyone know if Tesla will install the Powerwalls and inverters on the opposite side of the garage that the electrical panel is on? My main electrical panel is on the left side of the garage, but I would like the Powerwalls and inverters to be on the right side, as there is more room on that side, with virtually nothing on the opposite wall.
View attachment 586407 View attachment 586408 .
Thank you for the quick response jjrandorin. I am OK with a surface run of conduit, might bring some flare to my boring garage. I got my initial design today, it just shows the layout of the solar panels, and mentions the powerwalls and additional equipment will be installed near your power meter. On installation date the Tesla crew will discuss exact location based on preference and feasibility.
I would recommend speaking with your energy advisor (email, etc) and letting them know what you want, somewhere on that wall in the garage, and send them the two pictures inside the garage if they were not part of the survey pics you sent in.
"Exact" location would be "where on this wall", but since you want it on the opposite garage wall I would just make sure its in your file somewhere that you asked for that. I am not an expert, but I believe it would be fairly simple for them to surface run conduit to the other side of the garage. What I dont know is, which devices, if any, will still need to be on the wall with the panel.
