  • The final cut of TMC Podcast #29 is available now with topics time-stamped. We discussed the Tesla Cybertruck's expected 1 MW Ultra-Fast Charging capability, the Tesla Semi Delivery Event, the coming Model 3 refresh (project "Highland"), and more. You can watch it now on YouTube.
I am looking forward immensely to my upcoming retirement, not least because I intend to spend large chunks of the year exploring Europe on a boat - exactly which boat is yet to be determined, but it is going to be a flybridge cruiser in the 50-foot range. We will spend a few weeks on it at a time, and then it will be laid up doing nothing for a few weeks (possibly up to four or five months if weather is poor). What do you all think about installing a powerwall? It seems to me the advantages could be:
  • Not having to run the generator at night to run the aircon, which will make life a little quieter and reduce vibration when we are trying to sleep
  • Not having to hook up to shorepower (which can (a) be expensive and (b) cause issues with galvanic corrosion of the metal parts which are in the water) during the periods we aren't using the boat, yet still allow us to keep a couple of dehumidifiers and an alarm system running
  • Potentially reduce running costs since we would be running the generator less
  • Permit the main boat batteries to be kept topped up during the periods we aren't using the boat (as you all know, batteries discharge over time even when not being used, and deteriorate, potentially to the point where they are useless and have to be replaced)
Obviously we would have a couple of solar panels on the boat to top up the Powerwall when we aren't using the boat, although space limitations mean it will be nothing like a normal domestic solar array. Presumably we could also connect the generator's output to it, and perhaps also the engine alternators?
Meanwhile, the downsides seem to me to be:
  • Weight, and accordingly increased fuel consumption when on the move
  • Placement (the obvious place from the space and ease-of-connection perspectives would be in the engine room, but they get pretty hot when the engines are running - it's a fairly confined space and the engines are likely to be a pair of diesels of approximately 11-litre displacement (possibly more) so as you can imagine they generate a bit of warmth, and the space also includes the hot water tank and a generator
  • It is common for boat systems to be a mix of 12-volt, 110-volt and 220/240-volt systems - although I imagine that tapping the Powerwall into the same output points as the generator would solve that since the onward power transmission systems would have all the necessary gubbins built in
Not yet owning the boat I can't give you much guidance on electrical demand other than to say that we will have an upgraded aircon system which means (according to our enquiries in relation to the hot favourite boat) that we need an upgraded generator, with a nominal output of up to 12kW and 15kVA, instead of the standard 8kW unit. At night (which is when we would particularly want to use the Powerwall) the main draw will be the aircon, which is a 74,000 BTU system.
As regards daytime load - some aircon use but not much as we will generally be in the fresh air, and otherwise similar to a small home (cooker, oven, kettle, washer/dryer, fridge, freezer etc) but less likely that we will use it for hot water, since we would expect that to come mainly from the engines (boats typically have the hot water tank "powered" primarily by a heat exchanger connected to the engine cooling system). The only unusual bit of kit we are likely to be running is a watermaker but would probably only use that during the day (when engines or generator can provide the power).
Anyway, I am no expert on any of these issues so would be really grateful for any thoughts this community might have!
miimura
7,400
7,404
Los Altos, CA
You would be much better off with a system designed to run off-grid. They are much more flexible and can handle inputs from solar and generators with poor waveform quality. You could use battery modules from a Tesla or another EV, or Lithium Iron Phosphate batteries with these inverters. People do this kind of thing with RVs and a boat is not that different.
1) A single Powerwall is rated for 5kw continuous output....it won't even run your aircon. And if it did, it would deplete it's 13.5kwh capacity in less than 3 hours.
2) How many solar panels do you think you're going to deploy on a 50 foot boat? If a single panel produces 330watts peak....do the math on how long it will take to recharge a 13.5kwh battery.
3) You can't charge the Powerwall from a generator.
4) If you are at sea you very likely will not have a cell phone signal for the gateway to communicate with Tesla for diagnostics, updates, display of data on the mobile app, etc.
5) Tesla only sells and warranties for grid-tied use.
Great idea but the technology just isn't quite there yet.
Reactions: Snerruc
tes-s
3,388
5,551
Connecticut
Gunboat has been doing electric systems for several years, and the technology has advanced greatly.
Here is a link with the basics: GUNBOAT 55 ELECTRIC HYBRID CATAMARAN
They have much larger loads than you are talking about - but it is designed for boats. The boat I am familiar with has 2 x 10kW generators that start automatically when the battery gets low, usually running one generator at a time and alternating between them. When using motors and going at higher speeds, both generators are needed.
Look for a marine solution. Tesla is not a good fit.
Check out Sailing SV Delos on Youtube. They have a very realistic Lithium system on a sailboat. Upsizing that sort of system is definitely the way to go with your demands. Tesla Powerwal is not at all suitable in that application. You have to look for marine/RV specific solutions. Add as much solar as you can. Hard bimini on flybrigde should be great place to put some decent amount of solar.
Also, if you are planning on bringing a boat from US to Europe, be sure that the electrical system is capable of handling 230 V shore power.
Reactions: Shygar
jjrandorin
Moderator
Nov 28, 2018
16,805
22,235
Riverside Co. CA
SV Dauntless, a YouTube channel, installed Tesla battery packs. Watch their video.
This is an old thread, and I am not going to watch the video, but your description says "powerpack". That is a slightly different product than powerwalls. The powerpack is a commercial product I am fairly certain. Also, I would imagine that using a powerpack (instead of some other type of battery storage solution ) would likely be one of the most expensive ways to do this.
I dont have (and likely will never have) a boat, though, so this is conjecture on there being other battery solutions already for this application.
Reactions: Ampster
Interesting this old thread coming to life.
Powerwall system certainly can be connected to a generator, though I am not sure about mobile applications of the unit itself. I can't think of reasons why it wouldn't work. It does have an off grid mode where its only connection to power sources is a generator and PV.
Realistically, a solution from Outback or similar will likely give you more flexibility, and lithium modules are not Tesla specific.
Reactions: Ampster
