Powerwall required clearance and other details
ecarfan
19,186
13,841
San Mateo, CA
Probably no one has the info I'm looking for, but thought I would ask anyway since there does not seem to be a way to contact Tesla Energy and get this information.
I am planning a solar system for my house and want to position the inverter on an outside wall and allow sufficient space for a Powerwall unit to be right next to it. My wall space is limited at the location where I want to put the inverter and Powerwall.
I would really like to know if there is a minimum required clearance around the Powerwall, particularly at the top. I know it is rated for outside exposure, but am wondering if there are any cooling vents at the top, bottom, or sides that cannot be obstructed.
Also, I don't know where on the unit the wiring connects into. From the bottom? (seems most likely) On the side? (I understand they can be connected together directly side to side) Choice of either? I assume not from the top.
essaunders
130
37
Nashua NH area
http://www.solaredge.us/files/pdfs/preparing_for_storedge_upgrade_on_grid_and_backup_na.pdf
siucity
Button Pusher
Feb 18, 2015
407
208
SF North Bay, CA
Have you thought of going with microinverters?
ecarfan
19,186
13,841
San Mateo, CA
@essaunders, thanks very much for posting that diagram, it's exactly what I was looking for.
@siucuty, I am probably going with a Solaredge inverter. Not planning on using micro inverters. My roof is essentially unshaded.
