I should probably read up on the Power Optimizer thingy but my gut tells me they simply maximize DC harvest from each panel. By definition, these must be paralleled into a DC-AC inverter as no two panels (with optimizer) will produce the exact same current thus they can not be put in series. The Power Optimizer likely produces a reasonably tightly regulated DC voltage. These did not appeal to me as it meant relatively high current low voltage DC runs coming off the roof.
As for using them with a PowerWall, it would be terribly inefficient to take high current 35-60 Vdc and boosting it to the levels necessary to charge the battery. It would also be an expensive and heavy DC-DC converter.
