h2ofun
3 powerwalls here. Solar will charge PW IF IF IF the grid is on, otherwise, no. Lotta good that does! PWs shut down from using up all the batteries, and we live in the dark.
That does not make sense.
this is the relevant and inaccurate statement
Something is wrong in your setup. As long as you have excess solar generation, the Powerwalls should recharge from this excess. Time to get it looked at if this is not the case.3 powerwalls here. Solar will charge PW IF IF IF the grid is on, otherwise, no. Lotta good that does! PWs shut down from using up all the batteries, and we live in the dark.
One has to have their priorities.My nighttime consumption is around 500W pet hour. I blame my beer fridge for the additional load.
Yeah that statement is wrong. One of the big (sometimes overlooked) benefits of Powerwalls (and similar systems?) is solar inverters can continue to work even if the grid is out. One can clearly see that in the graph in my first post (the only power source I have other than the grid is solar...no e.g. gas generator). If I didn't have Powerwalls on the other hand, then my solar would have been useless for the past two days.
Bruce.
I just loved that part of the outage where Bruce had filled up his PWs and dumped excess PV power into an EV
We do the same when the grid is down. Don't want that solar energy going to waste! Our normal household usage around 1 pm would be about 1 kW but I can bump it way up by charging a car or two.I just loved that part of the outage where Bruce had filled up his PWs and dumped excess PV power into an EV
Fortunately, our utility credits us the same rate they would charge us. When the grid is up, we try to export nearly all of our solar at ~$0.12/kWh (part-peak) or ~$0.20/kWh (peak). We have the Powerwalls programmed to power the house for all but 2 hours of the day. Then we charge at the $0.08/kWh off-peak rate.A common occurrence for me in the summer when the PowerWalls are full by 11 AM. I would rather put the juice in my Teslas than send it back to the grid for a paltry $0.04/kWh.
I have not been on the program before, but my understanding is that as part of the NEM program PG&E only pays us the wholesale rate for any power we put in the grid. And these rates are around $0.04/kWh. Please let me know if I am wrong.why are you only getting 4 cents?
Only for the kwh in excess of your consumption.
