Hello all,
I'm in the EU and I had my system installed back in August. I have a 6Kw system with 2 Powerwall 2's installed (the plus are not available here yet I guess). Everything is turned on and it's been functioning 90% perfectly except for the PowerWalls refuse to come out of standby in non blackout scenarios. The situation:
Main Issue
Going back to above #4 in the list, if I log into my gateway via it's static IP and click the "go off-grid" button in the gateway dashboard, it works. I run off the Powerwalls just fine and they power my home in "off-grid" mode. This is what I've resorted to doing to avoid using the grid the whole time the system has gone PTO, hoping for a fix to this extremely aggravating issue. Now if instead I go into the Tesla app on my phone, and use the "go off-grid" setting there, it FAILS, and says my home is consuming more power than the Powerwalls can handle, which of course, is not true. I never push past the 5,5Kw continuous limit and have tried this even with extremely small loads of 200w, 100w and even turning everything in the house off and having only a single light on, and it still throws me this error and won't go off-grid via the app. This is where I believe this is either a symptom of whatever is wrong, or a potential cause of the issue. I'm no wiring expert on Tesla Energy Systems, so I don't know if some incorrect wiring can lead to the system working this far but then causing some heartache in the Gateway's computer that makes it avoid discharing the powerwalls in self consumption mode. I've told this to my installer, who is now going to get back to me as they've never seen this problem before.
This thread is exactly what is happening to me, except for this person the system worked for 9 months and for me it has never worked. I've already power cycles the Powerwalls themselves by leaving them off for 10 mins, and I've hit the reset button on the Gateway as well to let the system reboot, and the problem persists. I'm an IT guy so by nature I like fixing stuff on my own, so if I can do that without needing my installer on site again I'd rather just fix it myself (and avoid Tesla's support based on all the horror stories I've read on here).
Anyone seen this before and have any suggestions on what to do, besides waiting for my installer to come back and look at the system again?
Thanks!
- The solar works and powers the house and exports to grid perfectly fine.
- Simulating a blackout by cutting off main service works, and the system goes into Blackout Mode
- An actual outage works and my Powerwalls power the home
- Simulating a blackout via the gateway off-grid mode half works, and is either a symptom or the main issue. See more below
- Batteries charge no probs when an outage occurs or I force off grid mode and solar power comes back following sunny day
- Self consumption does NOT work. When the sun starts going down or is fully gone, the Powerwalls never come out of standby and I'm always pulling from the grid. They absolutely refuse to power the house
Main Issue
Thanks!
