Pre-conditioning on new update
Discussion in 'Model 3: Battery & Charging' started by torch0395, Nov 23, 2019.
  1. torch0395
    torch0395 Member
    New York
    If we chose to pre condition cabin during weekdays, what happens if we don't use the car that day? Does it turn off the pre conditioning after a set time or it just stays on indefinitely? Couldn't find anything on this.
  2. BikerPeaBody
    BikerPeaBody Member
    Virginia
    what exactly are you preconditioning? just turning on the heat or defroster?
    but I don't have an answer for this. of course you can just always turn it off with the phone later
  3. justsomeguy
    justsomeguy Member
    Vancouver, Bc
    I've read that it just stays on forever.
  4. BobAbooey
    BobAbooey Member
    usa
    this why i did not turn it on, if i call out of work my car will be "running" for hours
  5. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Yeah my GF works from home on Wednesdays and we have the same issue. If she doesn’t go out early for something else we need to remember to turn it off then or the night before.
    Def hope they add a more detailed calendar for this soon. (Never mind the ‘stops at 0600’ just because California does. smh.)
  6. Matsayz
    Matsayz Active Member
    Las Vegas
    You can always just open the app and turn off the hvac, you don’t even have to leave your bed
  7. boaterva
    But you have to remember... :) It would be nice if it had a notification for climate. It’s not so bad the charging is delayed if you don’t have a TOU plan.
  8. Matsayz
    Las Vegas
    Other option is to tweet Elon. I do agree it’s amazing how Tesla can create a “wow” option then totally ignore adjusting it for 6-12 months while we’re banging our collective heads against the wall.
  9. boaterva
    It always gets me how it seems no one at Tesla uses their own stuff. The suggestions we have to provide seem obvious to anyone that actually drive and use the cars. WTF?
  10. afadeev
    afadeev Member
    NYC
    Makes a little more (just a touch) sense if you recognize that it doesn't get cold, nor rains much in Nor.Cal (Bay area in particular).
    Thus the interior pre-heating and rear trunk lid rain flooding use-cases don't get exercised, much.
  11. morningstar
    morningstar Member
    Indiana
    I wondered if I was the only one! Hadn't seen anyone else complain about that yet. How do we make improvement suggestions to Tesla? Is tweeting Elon the only way?
  12. boaterva
    True but originally they tested cars ‘everywhere’. You’d think they would still do that and take suggestions from beta testers. And they do have employees ‘everywhere’. :D
  13. TM3blu
    TM3blu Member
    Arizona
    The Chevy Volt has a programmable 7 day timer, with provisions for seasonal rates changes. In AZ, TOU has different summer and winter schedules. Program the car once, you're set for life.
    I wish Tesla had a simple time on - time off setting.
  14. boaterva
    This software has only been out for what a few weeks? I’m sure it will be improved to have a full week’s calendar and time to stop charging, etc. it only took how many years to get ‘charge to leave at X time’, right? :D
  15. Ol'Blue
    Ol'Blue Member
    Vancouver
    I find it stops charging long before that time and it’s mostly just maintaining the temperature. To the point that the batteries are not as warm as if the car had just stopped changing.
    I’ve gone back to charging the car at a specific time to make sure my batteries are warmest and most efficient again. Hopefully they will update the parameters a bit soon so that the batteries aren’t left cooling.
  16. TM3blu
    TM3blu Member
    Arizona
    When I want to start out with a nearly full battery. I set my charge to 95% the night before, then reset it to 100% the next morning. Battery will be warm and car is good to go.
  17. enixneo
    enixneo Member
    Texas
    Let's confirm this before jumping to conclusions. Has anyone else experienced this? I'm at work now but I'll try to check myself.
    If this really is the case it seems like a big oversight. What would happen to my car lets day... over the Thanksgiving weekend? It would run in-cabin heat until I use the car again on Monday?!
  18. torch0395
    torch0395 Member
    New York
    this is why I havent enables it yet. No mention of shut off anywhere.
  19. 1.21GW
    1.21GW Member
    Michigan
    I have tested this by accident. It does shut itself off after some time. I’m guessing around the 30 minute mark, but I’m not exactly sure.
    I work from home many days and checked my car mid day and it was cold. Then one morning I was going to head into the office and realized the car was warm because I set departure time.
    I’m sure someone can do a more exact test
  20. RickW
    RickW Member
    Seattle
    I took another car in today and forgot to turn off the preconditioning. It turned itself off. It did use up 1% of battery doing so. Unfortunately I cannot tell you when it turned itself off though. The software needs to be included in the phone app. I was using Stats before this and may go back to it since it does the same thing.
