A kind of related question. My other half is mainly using the car at the moment, she has an 8 mile trip to work. So far I just plug the car in at 17:00 ish to charge up to 90%. I then turn on the climate 45mons to 1hr before she leaves at 9am the following day. Taking out of the equation it’s nice to get into a warm car, what's most efficient from a cost to charge:
- Don’t bother pre-heating and just start and go
- Pre-heat whilst plugged in before departure
I assume if you don’t pre-heat the efficieny won’t be as good as if I’d pre heated. However, it has ‘cost’ me (via a 12.6p per kWh tariff) to gain that efficiency.
Obviously if my strategy was to eke every last mile of range I’d fully pre heat, but if range isn’t a concern for a particular journey I’m not sure which is the best strategy?
I have a theory that it’s the same regardless. It’s perhaps ‘jam tomorrow’. Pre heat you spend at the start of a journey, don’t pre heat and you spend at the end?
All musing welcomed
