Preconditioning for an hour??
I recently updated to 2021.4.11 and had need to travel from San Diego to LA, and set a supercharge stop about an hour away. As you can see in the attached photo, my car started preconditioning, even though I was 65 miles away from the charging station (nav was set to the L3 charger), and it was a very comfortable 65F outside so obviously no winterizing conditioning was needed. I mean, it's San Diego; the weather's always great!
Has anyone else seen this? I didn't see really long preconditioning previously, so thought maybe I'd ask on here and see if this is something new/something I should have looked at.
"A very comfortable XXX" outside has really no bearing on what the temperature of your battery is, and if you set the destination to a supercharger, the car will warm the battery to a temperature that it thinks is appropriate for fast charging. It would likely warm up the battery to the proper temp for fast charging, then stop pre conditioning.
TL ; DR, there is nothing for you to have looked at.
Upvote 0
Noticed this yesterday when I input a SpC 40 miles away - it started pre-conditioning immediately. I had been driving for 45 minutes - how much pre-conditioning is required Our temps are 60 - 70 outside. Car had been operating awhile.
Previously 'pre' would be about 10 minutes out. Caveat: I had not SpC'd for couple of weeks, so maybe things have changed.
Upvote 0
The computer knows when to start preheating the battery for supercharging. I couldn't guess why it started that soon. Was the car sitting overnight before you started driving it?
Upvote 0
They may have changed it to try to harvest more heat from the motor at an earlier time, though I thought it was basically always doing that, and started calling "preconditioning" so the driver knows it's warming the battery.. The earliest I've seen was about 30 minutes, but I haven't done a road trip with the new firmware yet.
Upvote 0
