Hi, everybody. This poll is part of the Tesla Predictions Competition. Check out the competition rules there if you want.
1. Once you submit your vote, you can't change it.
2. You get 10 points for the correct answer.
3. You get 2 points if your answer is 5 kWh above or below the correct answer.
4. This poll is about the advertised capacity. For example, imagine Tesla releases a trim level called "Model 3 35" which has a 40 kWh battery but it is software limited to 35 kWh. The battery sticker shows 40 kWh. However, the actual capacity is 42.5 kWh and usable capacity is 38.5 kWh. The correct answer in this example would be 35 kWh.
5. If the answer is published by Tesla, leaked by other sources or tweeted by Elon before the poll closes at the set date and time, then the poll will be considered closed instantly and new answers won't count. In other words, if the answer is already known, you can't use that information to answer this poll and even if you do, your answer won't towards your score in the Tesla Predictions Competition.
Thanks
Thanks
