Found this gem that was posted a while back...
Source: Model3OwnersClub
Consensus seems to be:
- As long as the ambient temperature doesn't drop below -30C for longer than 24 hours, the car will take care of the battery itself. Otherwise, find somewhere warmer to park it.
- If you don't pre-heat the battery, you will definitely have reduced range or much slower charging until the battery warms up.
- If you want to pre-heat the battery, just switch on cabin control at least an hour before you head out, preferably hooked up to "shore" power.
Battery chemistry is virtually the same. It's still NCA, but with further reductions in cobalt. Source: Two Bit da Vinci via InsideEVs
Also, I think you took @Rocky_H's post a bit too personally. He (or she) wasn't attacking you. Basically his argument, extrapolated, was a generalization is that Tesla is building vehicles for the mass consumers and it should be as simple or easier than owning an ICE vehicle, or actually even worry less than one. We're all here to help each other and answer to the best of our abilities. Here are some of the questions you asked:
He (or she) is basically pointing out that you shouldn't have to worry about any of these conditions other than what was stated in the manual of extreme temperature. To answer your second question, yes. Preheating the cabin will also activate the Model 3 heater, if the BMS determines it is needed as you can see from the image above.
3rd question is answered in the manual on Page 44 for the Model 3. It has the same verbiage as the Model S/X owner's manual:
4th and 5th question, it would be the same for any of the Tesla models. It's up to the BMS to make sure the battery stays healthy. But back to Rocky_H's extrapolated point of "K.I.S.S.", the manual says as long as the vehicle is in an ambient temperature higher than -30C, the vehicle should be fine. I've left my car at an airport for 5 days, unplugged in very cold weather, and it was fine when I got back minus a bit of vampire drain. Does leaving a lithium battery in cold weather affect the longevity? From my previous academics, it's negligible until certain extremes (i.e. colder than -30C for Tesla) and mostly occurs if you try to PULL or PUT too much into the battery (hence the no regen, slow charging, power-limited/slow acceleration). If the battery is basically not being used, there should be little to no degradation, in terms of longevity, at all to it.
Hopefully, some of this will help put your mind at ease and not to sweat it too much. And if there are any more definite answers to your questions, I'm sure they will surface up and provide more information.
Cheers.
Thanks again for your valued input. It looks like the attached screen shot you provide is from the mobile app for Model S. My mobile app looks slightly different, so I will have to wait till it gets a little colder to see if it displays the icon for battery heating. The image shows an interior temp of -8, I am about +10 at the moment. Anyway, thanks for the tip on page 44. I must have passed over that. In regards to the Model 3 battery, I read over the section starting on page 109. No where does it state one way or another that the battery will be kept at some temperature level when unplugged, or that the battery heating will be activated by turning on climate control when unplugged. On page 44, it states that you can preheat the battery using wall power when plugged in, but does not mention what happens when unplugged. On page 111, it mentions that a 1% drain to power the onboard electronics is normal when not plugged in, and recommends that the user should ensure enough charge level to account for this when leaving Model 3 unplugged for extended periods of time, such as at an airport. Taking both of these information sources together, I have to believe that when the car is left unplugged, there is no active heating of the battery, even when climate control would be turned on. Otherwise, the 1% battery drain would be much higher depending on the time of year and at which airport your car is parked. JNU, or LAX. Given the extreme temperature dips here in the cold white north, this may even extend concern to anyone having to leave their car outside unplugged while at work for 8 to 12 hours. I am not saying it is, or will be, I am just opening discussion on something I feel is important as an advocate of EV's... hence all the questions.
In terms of what is, or isn't good for a batteries life, I am certainly not the go to person... hence all the questions on a users forum. But in your brief explanation of why you think cold weather is not a factor worth concerning about, it seems to me that you give at least one good reason why a Canadian Model 3 owner maybe should be at least interested to ask. If battery degradation occurred at extremes, and mostly when you try to pull or put too much energy into the battery, wouldn't it then make sense to avoid cold soaking the battery in -25C weather for both longevity and performance issues? I think it is reasonable to expect that the driver might need to pull/put high amounts of energy out of/into the battery when they start driving. And remember, the questions raised in this thread are in the context of extreme cold weather up here in Canukville. So while we all learn from the collective experience here, it seems counter productive to discourage the inquisitive nature that underpins the purpose of an internet user forum.
In terms of Rocky_H, I respect his opinion and welcome it quite frankly, but when his opinion is that other's don't have one, it is less appreciated.
Cheers!
