Preventing audio auto-play
Discussion in 'Model S: User Interface' started by jgs, May 4, 2015.
  1. jgs
    jgs Active Member
    Ann Arbor, Michigan
    I've hesitated to post this because I feel I must be missing something obvious. But after asking a few friends, and spending some quality time with both my car and the manual, I've come up blank, so here goes.
    How do I keep the audio system from auto-playing when I return to the car? As far as I can tell there is no distinguished "off" setting for the audio system as there is on – dare I say – any normal car. If I stop the audio by pausing it, the pause doesn't stick when I return to the car after having been away from it. Of course I can reduce the volume to zero, but that's an ugly kludge.
    Surely there must be some way to do this. What am I missing?
  2. Barry
    Barry Active Member
    Colorado
    Press the left wheel and it mutes the audio.
    • Disagree x 1
  3. jgs
    jgs Active Member
    Ann Arbor, Michigan
    Yes, but I have to do that again every time I step into the car. I want to turn off the audio system and have it stay off.
  4. Zextraterrestrial
    Humboldt/Los Altos
    it used to be this way. not sure which firmware changed it
  5. llavalle
    llavalle Member
    Somewhere around Montreal in Quebec, Canada
    I think it's related to the sleep mode. I've had zero issues with "Energy Saving" switched to OFF... but set to "ON", audio almost always resume when I get in the car. VERY annoying.
  6. jgs
    jgs Active Member
    Ann Arbor, Michigan
    Thanks, all. It sounds like there's consensus that it's a bug – upside, I'm not crazy, downside, there's no fix. I guess I need to figure out how to file a bug report with Tesla.
  7. PaulR
    PaulR Supporting Member
    Atlanta, GA
    Glad to see I am not alone! I am enjoying my Model S, but this is annoying to me....
  8. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Why not just turn the volume down to 0 if you don't want any audio? Or you could tap the internet tab but not choose a station.
    • Disagree x 1
  9. Arnaud44
    Arnaud44 Member
    Châteaubriant, France
    I have the same "bug". Very annoying indeed.
  10. brianman
    brianman Burrito Founder
    Hold down the voice command button (right side of the steering wheel) and say "BUG REPORT ... " followed by your report. Try to keep your messages less than 30 seconds, as it seems to be more reliable (in my experience).
  11. bob_p
    bob_p Active Member
    I haven't seen this problem, perhaps because I have the "sleep mode" disabled, except when I need to use it for minimizing discharge when the car is parked for an extended period (like at the airport). The audio software seems to have problem when resuming from sleep mode - such as the auto-play feature mentioned here, or in losing the position or file of files being played.
    Unfortunately, the one mode that is guaranteed to always be turned off when entering the car is when playback was from a Bluetooth device. When re-entering the car, I always have to re-select my smartphone to playback from it. Wish they would fix that obvious problem - and retain the Bluetooth selection, if the same device is present when the car is restarted.
  12. ThosEM
    ThosEM Space Weatherman
    Annapolis, MD
    Well, I'm annoyed that the audio now turns off every time I stop and has to be turned back on when starting up again. Thanks a lot, guys!?
  13. jgs
    jgs Active Member
    Ann Arbor, Michigan
    Maybe we should trade cars? :)
  14. jhs_7645
    jhs_7645 VIN: #3305
    Camas, WA
    Can I get an Amen! And now that sending feedback to [email protected] is pointless, I guess this is our only voice.
    - - - Updated - - -
    I almost added all of my bluetooth gripes here, but decided a new thread was in order:
    http://www.teslamotorsclub.com/showthread.php/46905-List-of-bluetooth-features-lacking-%28my-vw-jetta-handles-bluetooth-better%29?referrerid=9907
  15. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Pretty sure this started with 6.2. It annoys me as well and I do have energy save turned on (but also set to Always Connected).
    As an aside, I started having a possibly related issue that I didn't see until the .188 release. Has happened twice now. Basically when getting into the car while on a phone call, it looks like the bluetooth connects to the car but the radio also starts playing on its own, but because it's in bluetooth mode, the pause/play control is greyed out so you can't stop the music (which shouldn't be playing when on a bluetooth call anyway) and it overrides the bluetooth audio, so you can't actually have a conversation.
  16. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    Now that would suck. I often get in my car while still on a conference call. I may have to learn to keep Bluetooth turned off on my phone until needed.
  17. jayman
    jayman Member
    Illinois
    I have this problem but I think it is a problem with iPhone automatically playing not the car?
  18. Cyclone
    Charlotte, NC
    Our 2011 Lexus will start playing music from the iPhone. The last Camry I rented did not, but the Altima a couple weeks earlier did. It's hit or miss on head units sending the play signal to the iPhone. My aftermarket Bluetooth in my 4Runner does NOT auto-play, but it also does not auto-pause. If it was playing when I turn on the car, it will transfer the audio to the car and keep going automatically.
  19. mspohr
    mspohr Well-Known Member
    So... some people here are annoyed that audio plays automatically and others are annoyed that it doesn't.
  20. mibaro2
    mibaro2 Member
    Georgetown, ON
    The other way to prevent the audio from playing is to turn down the volume to 0 (don't mute it). I do that everytime I leave the car. (mostly habit from when I was parking in a small garage. I wanted to hear if I hit anything. )
    When I get back in my tesla, I can't hear the radio unless I turn up the volume.
