Preventive eMMC replacement on MCU1
Discussion in 'Model S: User Interface' started by widodh, May 13, 2019.
  1. Spacey73
    Spacey73 Member
    United Kingdom
    How on earth can to turn logging off for system events?
  2. TonyT
    TonyT Member
    Orange county, CA
    @LuckyLuke in the Netherlands can help you.
  3. TonyT
    TonyT Member
    Orange county, CA
    The new updates seems to have turned them way down now.
    • Informative x 2
  4. Target
    Target Supporting Member
    Chicago Land
    Finally, something GOOD in an update!
  5. mrg2jz
    mrg2jz Member
    Milton keynes
    Hi Guys, Ive been trying to repair my MCU1 for a while now and having no luck with file recovery, I have DD-rescued the chip a few times with 99.97% rate of extraction but Partition 3 is a no go along with anything else. Has anyone got the files/partitions or some sort of backup/copy of the MMC that I could copy to mine to get the thing to boot up? After that point I have someone in tesla saying if they can log onto it they should be able to do the certs.
    Any help is greatly appreciated
    Thanks in advance
  6. widodh
    widodh Model S 85 and 100D
    Venlo, NL
    You mainly need the OpenVPN keys, the rest is not needed. You really want to have p3...
  7. T.R.T.e.s.l.a.
    LX
    Are you sure of that? How did you checked?
    And is that on all cars, just the recent ones, the older ones?
  8. TonyT
    TonyT Member
    Orange county, CA
    It's firmware version related not car age as far as we can tell. and we've looked at the logs ;) There are also multiple source confirmation of this in the forums.
  9. mrg2jz
    mrg2jz Member
    Milton keynes
    And if i have a dead eMMC?
    What I am saying is how can I get this to a point where it will boot up without the cars info on it, then I can have a friend at Tesla program it like it was a fresh unit....
  10. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    That is not obvious to me from what green tweeted. ?
  11. T.R.T.e.s.l.a.
    LX
    Ok, thanks.
    Can you give us an idea about the percentage of the decrease in logs?
    I mean how much % was the decrease in logging?
  12. Target
    Chicago Land
    Looks like the gzipped file size is about 50% of what it was pre-update based on that image.
    50% reduction will matter to newer cars (double the life), but on cars that the flash is already worn out, it will still kill them.
    • Informative x 2
  13. TonyT
    TonyT Member
    Orange county, CA
    If you have the proper tesla help you are fine. However this is usually the hardest part. Getting the right person to
    The logging is currently reduced to what it appears to when car is in use. Also turned to lower logging levels. So it will extend life. Also I think they are actively working the issue. So we will need to keep watching. @T.R.T.e.s.l.a. @scottf200
  14. TonyT
    TonyT Member
    Orange county, CA
    Dead emmc may not be totally dead. You just need the key files to recover. Your Tesla friend will be giving you the same files if he has proper access.
  15. TonyT
    TonyT Member
    Orange county, CA
    Also we currently see level change as car is in use. So depending on what he is doing on the days, the story here may not be complete. PS, we still recommend a eMMC upgrade in preventive ;)
  16. mrg2jz
    mrg2jz Member
    Milton keynes
    He can only program it if they can talk to the MCU so it needs to be responsive, he mentioned something about having the kernal running, I am guessing its on partitions 1,2 and 4?
  17. TonyT
    TonyT Member
    Orange county, CA
    I meant to say your friend should be able to restore the files for you if you build a fresh image for your Terga even without a recovery. 3 and 4 are where they run, but can be rebuilt. 1 and 2 are the image files. All can be rebuilt except for the key files on 3. Those need to be recovered, or restored by Tech with the right access.
  18. mrg2jz
    mrg2jz Member
    Milton keynes
    He works for Telsa service as apposed to being a low level pro, so I guess all he can do is plug it in and update or configure it.
    Could I not use someone elses backup without the certs? then he plugs it in and configures the car. or does that sound too easy?
    If not how could we rebuild a fresh image?
    Any help is greatly appreciated as you can probably tell, I am not that clued up with it just yet...
    Thanks
  19. Spacey73
    Spacey73 Member
    United Kingdom
    Thank you for the information
  20. BobA
    BobA Member
    Ghent, Belgium
    I replaced my eMMC in my P85 (2014).
    A good explanation to disassemble the dashboard and take out the display can be found in this Youtube movie: (starts around the 17th min)
    The only mistake are 2 screws above the steering wheel, to easily lift the dashboard. You should remove a cover first.
    After taking out the MCU I brought it to Dennis from "All Systems Go" in Terneuzen (Netherlands). Perfect service. He works together with someone from this forum and they read out the important files before desoldering. Replaced the old eMMC with a new one (16GB). Not all partitions were perfectly readable, so they gave me a clean version (reset). Technical details can be found in earlier posts here.
    Well done for a good price and very fast.
    • Informative x 3
