price and range boost
must just be tweaking the acceleration curves then to make comfortable less rapid. only way I can see they increase the range without adding cells.
Someone did mention a while back that the suspect the SR+ is the same a the old mid range version but software locked, like the old model s 60...anyone able to confirm or otherwise? I'll take more range for nowt!
probably software locked which then calls on the reserve cells of the mid range when the old cells die out thus extending longevity.
from what I remember seeing the standard range has a different size spec in reality than the full rang its a different layout or more packs or something.
