Gasaraki
Yesterday it was 87 outside and I had it set inside to 72 and it was drawing in outside air (not blue). The air was still cool (probably around 72F) so YES cars can mix outside air and inside air to maintain the proper temperature inside the cabin. If it can't mix air why bother drawing in hot humid air when it could just use the inside air which is already cool...yes, when it gets cooler (or warmer if you live somewhere cold) it will start drawing in air. i believe this is mostly just based on outside temperature and maybe humidity. For me it essentially never autoswitches to draw in air outside because its too humid and hot here even at night. However, in winter at nighttime it does often switch to outside air being drawn in. The magic cutoff seems around 23C or so. I guess at those temperatures it is more efficient to take the outside air and condition it than to use inside air - as the car needs to then turn on the heater to warm the air back up again.
The car afaik cannot mix outside with inside air. You either draw air in via the outside intake or via the recirc intake inside the cars.
People need to understand that the compressor is either ON or OFF, it can't control the temperature. A HVAC unit controls temperature by controlling the FAN speed and drawing in (mixing) hot outside air when needed.
