"Proactive" 12v battery replacement - good idea or overkill?
What an interesting topic. If these batteries typically last 3-4 years and Tesla’s insurance covers 4 years, then Tesla needs to replace 12v batteries free of charge (no pun intended) for most cars they sell new. Do other car manufacturers do the same? They usually have longer warranty on new cars.
Reactions: texas_star_TM3
exactly my thoughts. the basic warranty 4yr/50k miles covers the 12V battery (at least until now - and they can't retroactively just change the warranty terms for cars already sold and on the street...) - so if in fact for a majority of cars the 12V is only good for 3-4 yrs - that's HUNDREDS of thousands of cars needing a Mobile Service tech deployment + a new battery. Not cheap at all. Hence I believe that at least the engineers expected the 12V to last 4-5yrs ... I'll be waiting with replacing mine until next year when my car turns 4 and it's out of warranty.
Reactions: Jules72 and Hiline
So I asked my other 2 coworker who got 12v replacement. They had their battery replaced after 3.5 years and around 40k miles. They didn't have to pay for the replacements. If my warning message came up 1 month earlier I didn't have to pay either. My other coworker only has about 17k miles on his M3, and no warning message yet.
I don't think they "design" the battery for last only 3 to 4 years, but I think in reality they probably are (at least for the earlier cars 2018). It is kind of nice that they would replace them free of charge if it is under warranty. They could have said it is a "wear and tear" item and made you pay for it like a brake pad or something. The thing is that the pandemic may have slow this process down quite a bit with a lot of people worked from home for the last 2.5 years. It would help Tesla to push most of the owners past the 4 years warranty mark and Tesla does not have to pay for it.
Reactions: Jules72
Surely the cost difference in this bulk must be minimal?
It is precisely in high volume that even small cost differences matter, and in this case it isn't a small difference either.
For example below (note this size is not the right one for Model 3) just picking one MF style battery vs the same size AGM from the same manufacturer, the MF battery is literally less than half the price (closer to 40%). So even if Tesla has to swap it once under warranty, it'll still be cheaper than an AGM. If the battery can get past the warranty (which it seems some do) then Tesla has saved that money.
Hankook AXS46B24R AGM Starter Battery: Type 057
Hankook MF54551 Starter Battery: Type 057
not sure if I follow there .... how much is a tow to a service center if a dead 12V strands someones car on the road or away from their house? How much does a single deployment of a Mobile Service Ranger cost Tesla? Add that to the battery cost and an AGM style battery would definitely be the same or cheaper... and lastly: how is customer satisfaction holding up *if* the 12V battery dies within 3yrs?
Reactions: KenC
If it's Mobile Ranger it'll cost more, but for regular service, it's only $26 labor, so $111 total ($85 battery), still cheaper than an AGM. Again, Tesla probably designed it so it would get past the warranty period, so for the most part they save that swap.
Most common car battery life cycles is quoted at 3-5 years (with more electronics and app functions might be even less), so although there are people here that seem shocked for some reason, overall I doubt it's as a big impact on customer satisfaction as people make it out to be, especially if it is covered free under warranty.
I'm still interested what reset she did- two scroll wheels (soft), two scroll wheels with all doors shut, brakes, and longer press (full vehicle soft) or pulling the connector under the rear seat (hard reboot).
Off topic but I can’t help it. Please repeat after me: “Holding the brake during a reset does absolutely nothing.”
There’s absolutely 100% no difference whatsoever between holding the scroll wheels and doing that magical incantation you call a “full vehicle soft.” Such a thing does not exist.
Tons of info on the internet and TMC says it does. So if it doesn't, I'm just the messenger.
Reactions: Hiline
I believe there were cases of some reps saying the dual button hard reboot (with brake press), but Tesla's manual does not mention that method.
There is only the power off method (going into menu to power off) mentioned as a hard reboot:
Model 3 Owner's Manual | Tesla
Misinformation spreads fast. I can assure you - I'd bet $5,000 on it - that it does nothing. I've had both Tier 2 & Tier 3 support folks reassure me as such. Shout it from the rooftops - old wives' tale.
It may do nothing "now", but it was instructions from Tesla back then. I called Tesla a few times back in 2017 and 2018 for my Model X and 3. The reset instructions back then were the same. 3 Methods: Hold both buttons for 1st method. Hold both with brake pressed for 2nd. Go to the screen menu and select Power Off, wait like 1 min, and press the brake to power back on for 3rd method. Maybe now they changed the software to not require the brake press and go straight to 2nd method.
2018 model 3 LR, at 69k miles, 3 yrs 5 mos, car died in my home garage. no warning.
2016 Model S75, at 73k miles, 3 yrs 4 mos, car gave replacement warning, was able to get a service appt within a week.
i set a reminder to replace them at 3 yrs.
I am surprised that your battery lasted 3 years. When I bought a new 2015 Model S, Tesla Service said the 12v battery is lasting an average of 1-1/2 years. They were right, I went through 2 batteries in 3 years of ownership. My 2018 Model 3 battery was replaced in 2-1/2 years and the Mobile Tech was surprised it lasted that long.
This is likely very location dependent, as heat really does impact battery life. My 2017 Model X battery and my 2018 Model 3 battery are both original and fine.
Fair enough, didn't realise there was that much of a difference in cost.
There's obviously been these software updates to help, not sure they did the same on the s (although I'd assume they would).
so Tesla would be deploying 2 ranger visits and $200+ in costs/labor over just 4 years rather than installing a proper battery to begin with? Hard to believe that this is intended by the engineers. A 12V battery definitely should *not* crap out after just 2+ yrs.
Reactions: FloridaGary
