Problem with RHD accelerator position.
Discussion in 'Australia & New Zealand' started by raynewman, Jun 16, 2015.
  1. raynewman
    raynewman Active Member
    Brisbane, Australia
    In the Right Hand Drive Model S there is a hard piece of trim next to the accelerator (see photo).
    When one floors the accelerator wearing shoes with an "edge", that edge will get stuck under the trim (see photo 2).
    and one will head for the horizon at a great speed - BEWARE!
  2. ZTrekus
    ZTrekus Member
    Sydney, NSW
    That should be grounds for a recall. I remember Toyota recalled cars for fear the driver's mat could curl up under the brake pedal or something
  3. Trav
    Trav Member
    Perth Western Australia
    Jeepers! You have seriously big feet Ray!
  4. raynewman
    Brisbane, Australia
    Yup - size 12. My older sons have size 14/15. One's in the Constabulary.
  5. doctorwho
    doctorwho Member
    Eurobin, Victoria. Australia
    I agree with you and I'm only size 7 (Euro 42). The pedals seem to be offset to the left too
  6. Mark E
    Mark E Member
    Sydney NSW
    I've never even come close to snagging my foot on anything in the Tesla, in fact it has soooo much more space than other cars that I've owned.
    After seeing the pic above I took one of my own without the foot in it to show just how much room there is. Are your cars different?
  7. doctorwho
    doctorwho Member
    I think because the pedals are offset to the left then my foot naturally rests on the right side of the pedal rather than the middle
  8. Mark E
    Mark E Member
    Sydney NSW
    I haven't noticed any offset - jump into an air-cooled Porsche 911 if you want so see an offset!
  9. doctorwho
    doctorwho Member
    there are certainly others that are worse!
  10. Dborn
    Dborn Confirmed
    Sydney, Australia
    Not found any issues.
  11. doctorwho
    doctorwho Member
    You can see that the pedal arm doesn't drop vertically, it's skewed to the left to clear the wheel arch intrusion. If it had been able to drop vertically then that would be the natural position for my right foot. As it is now my foot sits between the piece of trim and the right edge of the pedal. It isn't a big problem, the main problem is that I'd prefer some space to the right pf the pedal for my foot when the cruise control is on and there isn't enough space. Again not a huge problem, a minor irritation that I'm happy to endure in return for the safety of a rigid strong body structure
  12. Dborn
    Dborn Confirmed
    Sydney, Australia
    As I said above, I have no problem and this is the first I hear about it. However a solution to the shoe catching would be to get some black cloth backed duct tape and seal the area between carpet and plastic trim. The floor mat should cover most of the tape and you most likely will not see a thing.
  13. raynewman
    Brisbane, Australia
    Duct tape isn't a bad idea. Floor mat is no where near it tho.
  14. raynewman
    Brisbane, Australia
    Earlier this month, I rented an older (LHD) Tesla Model S in California and noticed that there wasn't enough room between the brake and the wall for me to put my great foot on the accelerator without getting it jammed under the brake.
    Model S must be made for those with genteel feet.
  15. Dborn
    Dborn Confirmed
    Sydney, Australia
    At the showroom this morning, I noticed that Tesla is now offering rubber floor mats. These are moulded with a well. The sides rise up presumably to contain water from say snow melt. However, these may be a solution for you as I think they cover the join by design.
  16. Keiron
    Keiron Member
    Melbourne,australia
    Gudday Raynewman
    I have tried to duplicate the effect you described but no luck. I have a size 11 shoe and spend much of my time with the pedal hard down :scared:. Adrenaline is a great thing!. I wonder if the side kick panel is misaligned.? I will quiz the service guys in Richmond today as I am heading off now to get new Boots! 17k kms has seen the rears deteriorate dramatically over the past 1000Kms. Even traction control cant hang on to it.!
