These last two weeks, we took the car for two road trips in National Parks in CA: Lassen Volcanic and Yosemite.
In both cases, when planning the drive back from the park, the nav/energy graph initially showed a solid arrival charge near 20% at the Superchager.
But at some point in the case of Yosemite, while descending from the mountains the predicted arrival charge level was adjusted drastically. For Lassen, it forced us to hypermile a bit. For Yosemite, it forced us to add a stop.
In both cases, the initials route planning was done in the nav while out of cellular connectivity. Am thinking that once the car got online, it adjusted the metrics based on some unknown factor. And it clearly needed to do that, as the initial estimations were clearly off in hindsight.
This is the result for Yosemite:
As you can see, about 10 miles down the mountains, the grey bar suddenly went off the screen as if it suggested we should have left the Fishcamp Supercharger at something like 150%...
(We could still probably have made it home, but a lunch stop was in order anyway)
In Lassen, it predicted we would arrive at Corning SC with 20% charge after leaving from Lassen Peak (plenty of regen to be had). We got there at 7% by hypermiling it as the graph’s lines were parting ways like they had a big falling out. No sudden reset like Yosemite, just a clearly unattainable goal.
So initial calculations were way, way off. Is this something you have experienced? What would be the best channel to report this to Tesla (I did not use the bug reporting feature in the car at those times, and I should have I guess)?
