  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Problems connecting Gen 3 home charger to wifi
New charger is working fine. However, I cannot get it to connect to wifi. I've tried scanning the QR code with iPhone camera, which just gives an error in Safari (cannot connect). Have tried using QR scan app which doesn't do much. And tried setting it up manually in iPhone wifi, with name being the SSID and Password the [email protected] password on the label- still cannot connect. I feel like I must be missing something simple....thanks.
I had the same problem yesterday. The solution was to turn off cell reception on the iPhone. Afterwards, turn it back on.
Apparently the signal broadcast by the Wall Connector is not very strong, necessitating that you keep your phone right next to (almost touching) the unit and it will go through the required set up process without issues.
I just hooked up ours this weekend, be sure you do not have WPA3 enabled on your router. That was my problem with my eeros.
but getting 50mi/hr charge is so much nicer that the 5 we were getting!
good luck!
I misread, you cannot even connect to the WC, try to either cut your breaker, or hold button on plug for 10 seconds to deactivate the WiFi, apparently it turns off after 5 mins. But mine also disconnected a few times when connecting eventually I was able to connect fast enough and enter My home WiFi now it works
