Also having an issue with the rear hatch not closing all the way. I almost think it’s software because I can replicate the problem by ensuring all passenger doors are closed on the Y. When all passenger doors are closed and I open the rear hatch via the hatch itself or via the app, it opens fine. When I go to close it, it almost shuts, but doesn’t engage the latch itself. I have to manually push it closed for the last 1/4 inch, and then the latch engages. I avoid this problem by opening any passenger door (or drivers door), and it latches perfectly when closing - every time. It will only latch 50% of the time when closing if all passenger doors are closed, otherwise I have to watch it go all the way down and manually close it.
I’ve had a mobile service tech come out to adjust a piece of trim, but that didn’t solve the problem. He actually found the trim piece that goes around the latch was a bit broken and is going to come back out to reinstall that piece when the part gets in.
I also spoke with Tesla support over the phone and they had me perform both a power off (via security settings in the car) and a two-scroll button reset. After doing that, the door latched as it should for about a day, but the next day the problem was happening again.
For my case, because it closes flawlessly when any driver/passenger door is open, but only closes 50% of the time when all doors are closed, plus it worked after a power off function was performed almost makes me think that there could be some software issue.
I’ve also had no problem with it opening or hanging up when opening. I’ve adjusted he rubber stoppers, but that hasn’t helped, and made sure there were no instructions. It’s just an odd thing, but hopefully mobile service can fix or I’ll be taking it into the service center.
