Products that are safe for cleaning headliner
Discussion in 'Model S: Interior & Exterior' started by SeminoleFSU, Aug 4, 2015.
  1. SeminoleFSU
    SeminoleFSU Voluntaryist
    Atlanta, GA
    Hello folks,
    Quick question. Does anyone have a recommendation on a product that I can use to clean the non-alacantra (standard) headliner with? I put a large coffee on the roof today, which slipped off the roof and fell into the car (OMG) and splashed everywhere, including on the headliner... :scared::crying::redface:
    Need something that will take coffee stains out?
  2. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    Sorry that I do not have a solution, but I'm definitely interested in what you find out!
  3. SeminoleFSU
    Atlanta, GA
    I prob should've searched first.. there's already another thread... Black fingerprints on headliner-How to clean it off?
    MODS feel free to merge and kill mine off
  4. fructose
    fructose Member
    Portland, OR
    OPTIONS / SUGGESTIONS:
    1) Distilled water in a spray bottle is one option - spray and dab (avoid scrubbing) with an absorbent white cloth.
    2) A small handheld steamer - hot water vapor + white or light colored absorbent cloth and then dab the area once it is steamed well. Heated water vapor and a clean cloth is the best natural degreaser I've used and that leaves nothing behind once the water dries. I bought this steamer for general surface cleaning inside and outside of my 85D: Amazon.com - Vapamore MR-75 Amico Hand Held Steam Cleaner With Lifetime Warranty - Clothes Steam Generators
    3) If the coffee stains are still visible after #2, a diluted Oxyclean solution (distilled water + a little Oxyclean). This should chemically bleach the brown coffee stain and then you can dab away with a clean white cloth followed by round of distilled water or steam to remove as much of the Oxyclean solution as possible.
    Good luck and keep us updated.
  5. scaesare
    scaesare Well-Known Member
    NoVA
    My service center recommended "Spray 9" which I found at my local auto store.
    Have used it on a couple of spots with a white cloth to dab, and works well.
  6. Jean-Claude
    Jean-Claude Local Vendor - Southeast
    Atlanta, GA.
    A little 303 Fabric Cleaner on a towel. Pat and use as little product as you can. A water-based adhesive is used for headliners and moisture/water can break it down resulting in premature failure. Less is better with headliners.
  7. SeminoleFSU
    Atlanta, GA
    Thanks everyone! I appreciate the feedback!
  8. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    Oxyclean, or simply the active ingredient from Oxyclean - sodium percarbonate - does an amazing job.
  9. robby
    robby Member
    Andover, MA
    Which solution did you wind up going with, and did it work well?
