Programmable charging?
Discussion in 'Supercharging & Charging Infrastructure' started by Fr23shjive, Apr 4, 2012.
  1. Fr23shjive
    Fr23shjive Member
    Southern California
    Does the Roadster currently have the ability to have programmable charging? Meaning, you can decide when the charge begins. So if you get home at 6pm and set a timer so that it doesn't begin to charge till midnight.
  2. Fr23shjive
    Fr23shjive Member
    Southern California
    Thanks, I was looking around and couldn't find anything on the subject.
  3. Sparrow
    Sparrow S105/ Roadster 189
    Marietta, GA
    I like the way you can tell the Leaf when you want the car to be finished charging. Of course you can also tell it when to start, but I only use the finish function. Right now I use it so that the Leaf and Roadster don't charge at the same time, because the Leaf messes up the timer on the Roadster.
  4. MarkR
    MarkR Member
    N. Scottsdale, AZ
    Arizona Public Service currently has an EV charging plan that is estimated to cost about $196 per year if you are willing /able to charge the car between 11pm and 5am. $16 per month for "fuel" for the car will do nicely. A programmable charging system would be ideal.
  5. GSP
    GSP Member
    I also like to "charge based on departure time" with my Volt. Warms up the battery in the winter. This also minimizes the time spent at max SOC, which should help battery life in real EVs, which charge to a higher SOC than the Volt.
    GSP
