Programming Garage Door Opener
20180510_073451.jpg 20180510_073444.jpg it's this one. Do I need to stand up close? I was trying to get it to read from 5 get away with no luck.
Start the Homelink learn process on the screen and make sure you stand in front of the car, point it at the bumper and hold the button until your headlights flash. It can take up to 30 seconds. If your lights don't flash then it's probably not compatible. Of course you should make sure the batteries are good before you start.
Reactions: atlas310
The new battery did the trick. Thanks!
For the record, remotes have more-or-less omni-directional antennas. There is no way to "point" them at anything. It's not like an IR (optical) TV remote. Just hold it close to the car's pick-up, and it will work fine.
Reactions: atlas310
