Improved frunk lighting modification!
I made a
significant improvement to the frunk lighting modifications posted previously and on Teslatap (
Lights How to Improve Frunk Lighting | TeslaTap ). This modification will allow owners of the newer
Dual Motor Model S to improve Frunk lighting.
Initially I used the the Tesla Motors Forum plans for lighting up the Trunk and Frunk with low wattage ,self adhesive, waterproof LED lights (see parts list below) and a tip of the hat to
4SUPER9 for introducing me to Posi-Taps they ROCK!! I was also inspired by
Lights How to Improve Frunk Lighting | TeslaTap . I appreciated their detailed instructions of how to install a short LED strip in well the frunk but the newer
Dual Motor Model S lacks the well.
However I was NOT satisfied with the Frunk lighting result, the light was often blocked by stuff I'd stashed there. For example, I keep an ice chest in my Frunk, handy for ice cream and other cold foods from the supermarket, but the ice chest wedges into the well blocking the light. Plus when packing for trips such as this recent trip to Yosemite Valley:
The duffle bag I'd stuffed into the Frunk covered up the LED lights, I was back to square one. THE SOLUTION CAME TO ME LATE ONE NIGHT IN YOSEMITE AS I SEARCHED OUT ANY FOOD/LOTIONS/CRUMBS IN THE FRUNK THAT MIGHT ATTRACT BEARS. MY FINGERS WERE NUMB FROM THE COLD. Here's what I've done:
Run a second pair of wires around the driver-side Frunk bucket lining to about the 2 o'clock position, starting from the OEM anemic LED light:
Here's where I attached the Posi-Taps:
guided the wires around the side of the bucket lining:
run the wires under the rubber gasket:
and made a 1/8th" V-notch along side the clip, this will be totally covered up by the rubber gasket, on the rear side of the Frunk and won't allow any moisture intrusion (I've since driven through heavy rains without an ounce of moisture in the Frunk!)
and gently refitted the gasket over the wires being careful to not pinch or damage them.
I then guided the wires under the plastic funk-surround back to the washer hose.
and zip tied the wire to the washer hose at 4-5" intervals to a point 1/3 the way to towards the center of the frunk lid.
At that point there is a well in frunk lid where you can sneak your connectors (power wires mated to the LED strip).
I centered a ~10 inch strip of LED lights just being the Frunk sealing gasket:
and voilà excellent frunk lighting, no glare and an excellent improvement this already excellent vehicle.
Parts List
SuperbrightLEDs.com, St. Louis Missouri
Used 1- LED strip Part # WFLS–WW30–BK:50cm[19.7in] warm white $14.95, (2/3 length for the Frunk lid and 1/3 length for the inner-well light)
Posi-products.com use the Posi-Tap, which make the job very simple and do not harm the cars original wiring, I purchased:
Used: 1- BLISTER CARD Posi-Tap™ PTA2022M 6pc, part #ZRTL-641-6 $8.95
Radio Shack:
Used: 22 gauge, very thin, stranded Hookup Wire
Insulated Butt Connectors (need a crimping tool ~$8 and a bit of practice)
