During my DS walkthru, one of the settings was the "look-back" for projected miles. I originally chose the "30 miles" setting. Today I tried to change it to "5 miles". While the setting saved, the projected mile UI still reports that it's for the last 30 miles. I tried powering off the car (from the 17") and tried using the RESET from that UI. Any ideas what else to try? Thanks.
Charge again? And / or drive 5 miles. I'm guessing it just doesn't work like that (yet). I don't recall that detail from the walk-through, but I'd prolly leave it on the 30 miles one anyhow. It should just immediately recalibrate, of course.
I drove 60+ miles tonite. I switched the look-back setting after about 25 miles, then power-cycled the car, then reset the look-back data, then drove 30+. Still uses (up to) 30 mile history. And yah, it's charging at the moment. I don't have much faith that will jigger anything.
I don't even remember seeing the setting. brb while I check... oh, lol. That just changes the # of miles shown in the energy app. A much harder way to adjust it than just tapping the x-axis label on the graph. I'm guessing it was the only way for a while, but now is basically useless. ... like the 'show traffic' button for the nav system that is now on the map itself.
From what I understand, you can't change how many miles projected miles takes into account (aside from a reset, where it'll build up 30 miles again). Changing the graph does only just that, change the graph. I'll check my car, but I never understood it to be possible to change the projected miles look-back.
You can tap anywhere on the graph to cycle through 5, 15 & 30. Alternatively "pinching" the screen (iPad style) achieves the same result. - - - Updated - - - Ditto.
My DS actually introduced me to the concept as part of vehicle walkthru. To the degree of asking me which value I wanted so that he could set it up initially. Sounds like I need to follow-up with him in e-mail to make sure either -a- that gets corrected for subsequent walk thrus or -b- make sure they are aware of the bug.
I assume it's (a). The variations are too wild if you only look back 5 miles. For experiments I have reset my lookback when I'm drafting a truck on the highway so I can get my Projected range into the thousands, or I'll reset it right before I gun the car so even with a full battery I get a range of less than 50 miles. I assume the 30 miles is fixed because it offers a somewhat reasonable projection, as opposed to these wild short-term swings that wouldn't provide meaningful info for a driver.
