Proof of tire wear benefits of accurate alignment and rear camber
Discussion in 'Model S: Driving Dynamics' started by artsci, Sep 15, 2016.
  1. artsci
    artsci Sponsor
    Timonium, Maryland
    I'm almost religious about maintaining front and rear wheel alignment. I also have the adjustable rear camber links which enable setting rear camber very close to -1.00.
    Here are the latest tire wear reading from my service center. Totally even -- this is with about 30,000 miles on this set of tires.
    Measured tire tread depth at:
    (Outer) (Center) (Inner)
    LF: 3/32 3/32 3/32
    RF: 3/32 3/32 3/32
    LR: 3/32 3/32 3/32
    RR: 3/32 3/32 3/32
  2. BrokerDon
    BrokerDon Active Member
    Newport Coast, CA
    What tires are you running?
  3. artsci
    artsci Sponsor
    Timonium, Maryland
    245/40R-20 Pirelli Cinturato P7 All Season Plus XL. They were replaced this am with 245/40ZR-20 CONTINENTAL EXTREMECONTACT DWS 06 XL. Go in next Saturday (not to Tesla) for an alignment
  4. BrokerDon
    Newport Coast, CA
    What year & Model Tesla ?
  5. GHammer
    GHammer What a long strange trip its been.
    Wren, Oregon
    I have those on my P85+ and love them.
  6. artsci
    artsci Sponsor
    Timonium, Maryland
    2013 P85. Early adopter:)
  7. Spurkey
    Spurkey P04251
    Edmonton, Alberta
    What toe settings do you use for the fronts as well as the rears?
  8. artsci
    artsci Sponsor
    Timonium, Maryland
    The recommended toe, .4 front and .18 rear.
  9. robby
    robby Member
    Andover, MA
    FWIW I have an 85D and mine are 7/32 7/32 7/32 7/32. Very well balanced stock.
  10. RandyR
    RandyR Member
    Danville, CA
    Quick question: Where do can I buy the adjustable rear camber links? Thanks...
  11. artsci
    artsci Sponsor
    Timonium, Maryland
    I don't have a record of the order but if you do a search for "adjustable rear camber links" I'm sure I posted the info.
  12. SUPRKAR
    SUPRKAR Member
    New Jersey
    Links are available from BBC Speed and machine in Linden NJ Google them and ask for Joe or Mike.
  13. tliving
    tliving Member
    New England, USA
    I have an April 2014 S85 and have 46,400 miles on my original factory 19" tires (I have a different set for winters). Only annual services as it relates to the tires. Quite happy with the miles.
  14. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    Just got my shipment from BBC Speed today! I have 2014 P 85+ and my rears tires wouldn't even make it a summer season with the staggered 21's - the car would eat the tires like a fat man eats donuts! I can't wait to get the links installed (once I pick them up from the Post Office).
    Confirming settings for P85+ - dropping the suspension to low then:
    Front Toe 0.4
    Rear Toe 0.18
    Rear Camber -1.00
    Correct?
  15. sorka
    sorka Well-Known Member
    Merced, CA
    I just replaced my tires. About 30K on the primacies (34K total with about 4K on the 21" continentals). I had an even 3/32 on all 4 tires in-center-out. Had probably another 4K in them but I just started doing weekly snow trips and the Primacies are rated pretty bad in the snow plus they were getting thin on the tread side.
    My rear camber is -1.5 to -1.6 as of this morning when I got my alignment done. I'm a little irritated that I didn't catch the fact that they didn't adjust my front left camber of -1 to equal the front right camber of -0.6.
  16. Xenoilphobe
    sorka is this a p85+ or a P85D?
  17. jcaspar
    jcaspar Member
    Sacramento
    Just replaced my original Michelins after 39k miles with the Conti DWS 06's. I like them a lot. The originals were down to the cords and I knew I needed a new set when I could only barely keep with my friends 2017 911S. Will be ready for him next time!
    Have never done an alignment. Artsci, do you have any recommended alignment specs for a coil P85?
  18. Xenoilphobe
  19. sorka
    Merced, CA
    P85D
  20. bhzmark
    bhzmark Active Member
    Is that a control arm under the sheet? did you so something with those?
