Xenoilphobe
These are the original camber links that they pulled off, I forgot to snap a picture of the new ones - they are beautiful with an engraved BBC logo and the phone number...
Is that a control arm under the sheet? did you so something with those?
Curious to see how your alignment shop adjusted the camber with the BBC's. Did he rip off the whole undershield/panel to adjust the camber? Even so, to properly tighten the bolt is from the top, but you have to remove the rims.
ExactlyThey removed the diffuser to get access. It's quite easy to do.
Exactly
Not the defuser which is at the back, right? You mean this, right?
BTW, I don't let Firestone put this back on. They mixed up the anchor screws with the machine screws and I had to use a threader to clean out two of that machine holes. So now I just put it back on myself when I get home.
That's it. Hard to mess reinstallation up if they keep track of which screws go where -- a basic organizing principle of auto service
I guess the shop i took it to wasnt bright enough to do it. I told him to remove it, but he said he wouldn't have the proper clearance for a big wrench to adjust the 1 1/8" bolt for camber from BBC. I even bought a stubby wrench for him to use. He actually lifted the rear, removed the wheel, adjusted and put it back on. I'm always worried about how the car settles after it sits back down. It was supposed to be a high end custom alignment shop that does alot of aftermarket camber kits for Porsche's, GTR's, etc...,Paid an arm and leg for the alignment. Which ones did you guys take it to? A local shop or one of those large franchises like FireStone, Wheelworks type of shops?
Where did you go?
I went to 2 shops. One was in Fremont - Auto Innovations. He wouldn't touch my car cuz he was afraid of opening a can of worms and the camber bolt wasnt very easily accessible. He was originally going to charge $150. He then referred me to Custom Alignments in Mountain View. They are even more expensive. Since it was aftermarket, they charge a minimum 2 hour alignment. ($150/hr). It took them 3 hours to align it. Granted, they have great service and they aligned it EXACTLY to the specs I wanted, but it was not cheap. Next time, I will remove the under belly guard to access the bolts more easily and hopefully, they won't charge me as much.
